87 GT died while driving, now wont start
Old Oct 24, 2014 | 11:03 PM
Twisted Whispers's Avatar
I was driving down the street today and out of nowhere, my car shuts off! Radio still going, no check ANYTHING lights, just a bunch of nothing! She'll crank and crank and crank, but just won't start. She recently sat for quite a stint, & I've replaced tons of stuff including the fuel pump, map, ignition control mod, coil, plugs, wires, & countless other parts that I've lost track of. I'm ready to pull my hair out, I just got her back after 7 years! HELP!!!!!!! 😫😫😫
Old Oct 25, 2014 | 04:39 AM
Welcome to TMS!
If its not even trying to fire then it makes me think of the coil. No ignition no spark plugs firing across the board. Loose wire? Loose ground?
If you've got fire, then its a fuel issue where the pump isn't getting fuel to the intake. Loose wire? Loose ground?
Old Oct 25, 2014 | 07:02 AM
Replaced the coil last night, distributor cap and rotor. Doin some more checking today, possible ground problems. I just absolutely hate wiring.
Old Oct 25, 2014 | 07:03 AM
Also gonna test the ignition control module, maybe it's bad...it's new, but not unheard of.
Old Oct 25, 2014 | 08:35 AM
ALMOST STOCK's Avatar
Have you replace the fuel filter lately?
Old Oct 25, 2014 | 10:17 AM
That's a possibility - esp if the car has been sitting and are just now adding fuel (with mandated 10% ethanol). That loosens up stuff in the tank and can plug a filter.
But my experience is the engine will start fine and idle OK. But when you drive away asking for more fuel flow, the clogging filter obstructs the fuel and you have problems like bogging.
Whereas she said its not even firing. Unless it is completely clogged.
Old Oct 25, 2014 | 01:22 PM
My experience with a clogged fuel filter was ........driving down the freeway got off at an off ramp still doing 50 MPH the engine dies for some mysterious reason, I coasted to a stop. The engine would crank over but wouldn't start.
Originally Posted by Twisted Whispers
She'll crank and crank and crank, but just start
That was the same problem I had ... it would crank and crank and crank and why I asked if the fuel filter has been changed because that was the problem with my car since I hadn't changed the fuel filter in probably 100K. Once I changed the fuel filter it fired right up.
Old Oct 25, 2014 | 06:07 PM
Changed the pump and the filter, I'm getting fuel at the rail.
Old Oct 25, 2014 | 07:14 PM
To check for spark, we'd always take one plug out and ground the threaded portion (still attached to wire) against the head or block. Like lay a hammer on it or some kind of weight. Have someone turn the starter over and see if the plug is sparking.
If you're getting fuel and spark what's next... any kind of backfire event that would make you think valve timing jumped? Timing chain/gear break? (This is a pushrod motor right?)
Distributor gear break? Does rotor turn?
Throttle blades moving?
Whatever computer they have suddenly fail to cause it to die suddenly?
Something to do with O2 sensors and MAF? (I don't know what gadgets the 87's have. I have old school '83 300 I6 with a carb, and 08 & 10 ECU/Sensor controls, don't know much about in between years...)
Old Oct 25, 2014 | 10:12 PM
You know it did backfire that day...I'm replacing the distributor tomorrow. I ran out of time at the shop it's at. They're letting me work on her there because she shut down like 2 blocks from there and I don't have any way to get her home. :-(
Old Oct 28, 2014 | 11:00 AM
Fixed!!! New distributor did the trick! Thanks for all the advice. It's much appreciated! :-)
Old Oct 28, 2014 | 02:40 PM
Awesome!
kennyg
Aug 14, 2023 11:45 AM
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
SpectreH
Apr 15, 2016 03:12 PM
CoyotePremium13
Aug 18, 2015 07:28 AM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
