5.8 ho
Old Apr 28, 2012 | 03:46 PM
Tirefryer's Avatar
5.8 ho
What is the diff between a normal 351w and a 5.8 ho.....is the ho a better 351..... And would it be better for my fox.... Thanks
Old Apr 28, 2012 | 04:09 PM
skunk21's Avatar
The 351H.O. isn't anyting to get all worked up over, maybe during the time it came out but that is it really. It was made in the mid 80's came with a 4bbl and intake with a marine grind cam shaft, other than that it is the same 351.
Old Apr 28, 2012 | 04:22 PM
AlsCobra's Avatar
A Man Just Needs Some....
Stroked and forged 302 never look back.
Old Apr 28, 2012 | 05:56 PM
Tirefryer's Avatar
A local guy has a 5.8 ho for sale for a 100$ and was thinking of a spare block... Didnt think there was much diff between a ho and a w
Old Apr 30, 2012 | 08:50 PM
Tirefryer's Avatar
K just pulled the heads off the motor and 6 holes look good and the front two have a rig from the ring that u can click ur fingernails on...anyone know why the two front cylinders are the only ones to do this... Would u consider this to be a bad thing or normal on a 351...how much is to much of a rig before having to bore....or just a new set of rings...pistons look good and no scratches or groves in the walls...
Old Apr 30, 2012 | 09:05 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
They make a tool to cut that ridge out. Then just rehone the cylinder and go. Of course getting it bored is always a better option
Old May 1, 2012 | 07:03 AM
skunk21's Avatar
Just like bone stated I'd probally go with a bore job. depending on the how much of a ridge and what you have after you take it down and hone in the end a bore is probally the best bet but then again I'm sitting at my house and not looking at it either.
mustang_lurkers
Oct 4, 2013 09:26 PM
cdynaco
Feb 18, 2013 12:00 PM
Zacstang2
Dec 31, 2011 09:56 AM
fdjizm
Past Rumor Archive
23
Apr 15, 2011 01:34 PM
