1990 5.0 headlights leaking
Old Jul 14, 2012 | 09:22 PM
bryan10's Avatar
I replaced my headlights and they keep filling up with water. Anyone have any good ideas how to stop this? I hear it's a common problem when replacing the entire assembly.
Old Jul 15, 2012 | 09:46 AM
Hoss408's Avatar
This is a common issue with the less expensive headlight tail light assembly. A while back I purchased a set of tail lights from eBay at half the cost of factory style lights... They constantly build up condensation... Take them off and set them in the sun or use a blow dryer to evaporate the moisture... Take some clear RTV and create a seamless bead around the perimeter of the headlamp ( where it is already glued to the plastic housing ) allow it to cure and be certain your bulb connections have a good seal. This should do the trick!
Old Jul 15, 2012 | 10:21 AM
SilverSkoundrel's Avatar
could drilling a small drip hole in the bottom mess anything up?
Old Jul 15, 2012 | 05:11 PM
bryan10's Avatar
Thanks for the ideas, I'm going to take them out and see what I can do
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
