ugh
Old Oct 27, 2014 | 06:29 AM
buchanannc's Avatar
ugh
i have some issue with my motor. here is a list of what has been done and the main issue.. 289 bored .20 over . set of turbo swirl heads. howards cam 495 lift soild lifters new four barrel holley 650. summit intake.. motor is installed every thing hooked up.. starts then dies.. replaced the whole switch. new silo-node . new battery wires and new starer wire. and gets plenty of gas..
its acts like something gets hot then stops. is there a relay or something else like a bad ground wire some were.. any input will be welcomed..
Old Oct 27, 2014 | 06:34 AM
buchanannc's Avatar
sorry forgot its a 66 mustang convertible.
Old Oct 27, 2014 | 08:15 AM
does it die right when you let off the key or does it run for a few seconds after you let off the key and then die?
Old Oct 27, 2014 | 02:47 PM
mil1ion's Avatar
Attach a test light to the +terminal of the coil.
Put key in run.....does the test light illuminate ?
No.?
How about during cranking?
Do this and report back with results.
I'm here to help you.
Old Oct 31, 2014 | 05:50 AM
buchanannc's Avatar
found the problem. ground wire on the external regulator ground wire was fried and shorting out the power wire to it
TheTaminator
Jan 24, 2015 01:40 PM
DarrenGT
'10-14 Exterior Modifications
Mar 31, 2014 12:17 PM
MustangMan311
Apr 13, 2006 01:14 PM
NickDC123
05-09 Interior and Audio Mods
Oct 6, 2005 11:28 AM
conv_stang
1994-2004 V-8
20
Aug 13, 2004 01:16 PM
