Turn signal problem
Old Oct 18, 2006 | 04:09 PM
Harley's Avatar
Turn signal problem
The turn signals have gone out on my 1969 Sportsroof (351W). All bulbs appear OK, the flasher has been replaced and the emergency flashers work fine.
If it's a fuse, would the emergency flasher still work?
Any other ideas?
Old Oct 18, 2006 | 05:22 PM
my guess and its only a guess but I would think the problem is in the steering colum. Try replacing the bulbs and check all the sockets and wireing to them. Good luck
I think the flashers and the turn signals are on two different fuses
Old Oct 18, 2006 | 07:29 PM
Harley's Avatar
Fuse is OK. Bulbs look OK, too.
Where in the steering column should I start looking?
Old Oct 18, 2006 | 10:16 PM
Bulldog66's Avatar
Really sounding like a ground issue to me. I'd double check all wiring and grounds. Take a test light and work your way back from each bulb untill you find where the problem is.
Guessing it's going to be in the tail lights - had an issue simular not too long ago.
Start simple and check everything before you go diving into a steering colum or a fuse box chasing an electrical gremlin.
just my 2c, good luck.
Old Oct 19, 2006 | 04:48 PM
Harley's Avatar
It's fixed.
I'd replaced the flasher but didn't realize there was another, more hidden, flasher behind the radio. That was the culprit. The things I learn with this car...
PonyMuscletang13
Sep 26, 2015 02:33 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
DrisStang
Sep 14, 2015 06:20 PM
Linkspure
Sep 12, 2015 06:33 PM
Sep 8, 2015 10:45 AM
