rear springs
Old Apr 27, 2012 | 07:11 PM
rd127a's Avatar
rear springs
Anyone have any suggestions , how to get the front eye bolt out . I am going to replace the rear springs in my 68 coupe , but I can't get the front bolt to move . It appears to be frozen in . One person told me to use a torch ,but I don't like that idea , the gas line is real close.
Old Apr 27, 2012 | 07:24 PM
houtex's Avatar
Based on my sometimes ok memory of having a similar issue (wallowed out hole in the frame rail... just welded the washer to the rail in the position we wanted... worked fantastic! ), and this pic here:
http://www.mustangmonthly.com/howto/.../photo_38.html
Well... yeah, you might need a torch. At that point, I would simply cut the head off the bolt and be done with it. Without the head, that will be a lot simpler to bang outta there, I'm bettin'. The leaf spring can just be pulled off the frame rail because the bolt head's gone, yeah? You're replacing all that anyway, right?
Otherwise, a ton of PB Blaster or such, every 15 minutes, and beat the hell outta things to help it work through the rust/corrosion.
I don't think a torch is the best way Unless the idea is to cut the bolt off with it, or melt the rubber to get the inner sleeve to come out?... but whatever works is what you do now. For what it's worth, unless you rupture that line, it's likely not to be a big deal, as long as you don't intentionally hit it with the torch. Still.
Good luck!
Old Apr 28, 2012 | 04:22 AM
rd127a's Avatar
Thanks, I think I might try to cut the bolt out with a saws all. Not gonna be easy but I think safer. A friend told that was how he done it .
Old Apr 28, 2012 | 10:48 AM
FMSixtySeven's Avatar
There is a rubber grommet inside of the spring mounting sleeve. This rubber either melts or shrinks onto the bolt and often makes the bolt immovable. The torch is used to melt and soften the rubber to slide the bolt out. Cutting the bolt is harder, but it will work.
Old Apr 28, 2012 | 05:04 PM
rd127a's Avatar
I have the new springs and looking at them I see a steel bushing molded in the rubber . If the bolt is rusted and frozen to the steel bushing by melting the rubber the bolt still won't come out , the way I see it . That is way I though cutting on both sides of the spring I would be able to get it out . I really don't know if if this will work that's why I am here . any and all suggestions will be appreciated.
Old Apr 28, 2012 | 11:04 PM
houtex's Avatar
Correct, unless someone did something weird, there is a sleeve, and that is what's welded the bolt in, not the rubber. If it were rubber, that can just be pryed out, overall.
Now, melting the rubber? Sure... it'd be messy, but the spring would pull off he rubber that way... you'd still have a bolt stuck to the frame rail, but it might be easier to hack off... maybe.
Old May 4, 2012 | 11:06 AM
1999Pony's Avatar
Take a torch and a hammer. While heating it up hit each side with the hammer. The heat will soffen the rust and the hammer will move it. This won't make it easy, but it will help get the bolt out. After you've done all that, use a breaker bar or a ratchet with a pipe on the end to get leverage on it and it will come out.
Unless its so rusted that when you try and loosen it the head will just snap off anyway.
Fords4Ever
Oct 30, 2015 09:07 PM
Evil_Capri
Sep 11, 2015 08:39 AM
1001yos
Sep 8, 2015 10:05 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
