clutch plate replacement checklist?
Old May 5, 2012 | 06:43 AM
phendyr's Avatar
After replacing my heater core, the next item on my list is to repair the clutch.
68 mustang, 289 v8 w/ a 3spd manual
Right now, when I take off in 1st, I have to release the clutch completely before applying any acceleration, otherwise the back end just chatters something fierce.
I purchased my clutch kit (Ram kit, thoughts?), but as I started reading some other treads, I see it's pretty much a standard process to have the flywheel resurfaced.... Is there anything else I should consider replacing along with this job? Is the throwout bearing that comes with this kit good quality? anything else that I should consider replacing?
I'm don't have plans of swapping the motor anytime soon (only around 78k on it), or putting in a big transmission upgrade.
Thanks again for your feedback!
Old May 6, 2012 | 09:55 AM
68nwnmstang's Avatar
I've got a 68 with a c4 but I also have a 3 speed with everything to put it in except the pedals clutch what do you like better auto or the man
Old May 6, 2012 | 12:26 PM
skunk21's Avatar
you can do the pilot bearing while your in there also. ram is a good clutch so I wouldn't be afraid of the t.o.b..
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 23, 2015 03:21 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
GMAYS
Sep 10, 2015 06:19 AM
