OIL PAN REPLACEMENT
I have a '69 Mach 1 with a 351W and I was wondering if I can pull the oil pan off without raising the motor? The pan has been scraped at one time or another and is creased right next to the drain plug and I can't get a tight seal to keep the oil from dripping out. I'm probably going to replace the pan now if I don't have to go to too much trouble. It looks like I have clearance,but I don't know about getting it past the oil pump.
I put in a Canton 7qt pan in mine without taking the motor out, pretty sure you will need to remove the motor mount bolts though and lift the engine from underneath with a jack to give you clearance.
It was a few years back that I did this but I know I did it without a hoist. Just a little creativity under there!
Rando
Aug 25, 2021 11:12 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
