My questions today Electrical & what is this LOL
Old Feb 18, 2014 | 07:08 PM
Retire Firefighter's Avatar
First the Electrical
My dash light where not working so I removed and cleaned the head light switch. ( see picture). That got me out light working LOL. I replaced all the bulbs most I am sure where bad form the looks of them. Now I have dash light and turn signal lights ....Well almost. When the head lights or off the turn signal light work just fine. When the head light are on one works very slow and the other not at all. My thoughts Voltage ??? Battery good, even tested it with battery charger connected. Same thing.. So I am down to head light switch bad and not passing the voltage is should ? Or something in the Ribbon ?? You thoughts please ?
The what is this
Found under dash just hanging there (See Pictures)
Old Feb 27, 2014 | 12:19 PM
matcox83's Avatar
What year is the car? There is a part number visible in one of your pictures I just can't read it. Looks like it starts with D0 so I assume you have a 1970. Get the part number and Google it.
Old Mar 1, 2014 | 06:32 AM
Mat the worked one is under dash light and the other is part of a censer
Old Mar 1, 2014 | 10:46 PM
Poco's Avatar
Grounding is important as well...check all ground wires connecting to the fire wall. Your added resistance is coming from somewhere and cleaning your light switch terminals was a good start.
Old Mar 2, 2014 | 04:30 AM
Poco, thanks but I am not doing anything with them yet. I just found the hanging under the dash and was working on ID'ing them LOL...
Old Mar 2, 2014 | 04:45 AM
Poco's Avatar
I see that they are hanging but sometimes just mounting whatever is hanging might just break your grounding causing all the problems you just mentioned. Maybe.
Old Mar 2, 2014 | 06:59 AM
Thanks that could be part of it.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
SickShade14
Aug 29, 2015 04:18 PM
DarrenGT
Aug 28, 2015 10:01 AM
YepItsGreen
23
Jul 15, 2015 07:38 AM
