My 66 project pony
My 66 project pony
Just picked this up today, 66 coupe with 200 6cyl.
68,7XX miles. a few previous owners have tried to restore it with not much knowledge of restoring cars
, now its my turn
, now its my turn
good luck! they are way fun to cruise in.....bad thing is....a really stiff wind might blow you off the road if you arent ready for it!
..oh yeah...give it a bath stat!
Most of the body parts have been replaced, and some of the lower pan. interior has new carpet is all. the rest of the interior needs work, headliner is gone, dash pad is shot, and the idiot who tried to put in a new radio should be shot. The gauge bezels have been cleaned so much there is no chrome left, just grey plastic. Also gauges ( except speedo) do not work. The brakes are all new, 4 wheel drum, and it has a cherry bomb on it...LOL
Oh yeah it needs a bath and vacuume real bad.
That involves changing the front suspension, at that point I will change out the brakes to disc and add rack and pinion set up and with front disc also means rear disc too.Neighbor looked at it and sugested just having the 6 bored out and beefed up
still thinking about that. $$$ would be cheaper.Open for suggestions
my present focus is to work on the interior untill spring then will think about what to do then for the rest of it... ok thinking all the time
Ran out of things to do to the 07
Oh BTW, raining today. rear window leaks, orig. seals but it is getting a bath
LOL,
yeah right
, with whose wallet
not mine
347 stroker, 10k+
up graded suspension to hold the stroker, 2-3k
Recaro seats, $600 to 2K each
Dakota dash $600
AOD tranny, 2k
4 wheel disc brake setup to stop this thing, 2-3k
Not to mention the cost of installing most of this
and I havent even put a headliner in it.
Thanks Marcello
, with whose wallet
not mine
347 stroker, 10k+
Dakota dash $600
AOD tranny, 2k
Thanks Marcello
Ha!!! Actually, Doug knows that Marcello already sponsors project 73 dust-collector, along with project 93 armco collector, and project 05 parts-are-a-missing-again...
And 2 of those three projects haven't moved in so long, I think they are starting to look like Doug's new one!
. guess I can't talk too much, I don't even have a garage
X21, thanks for the offer, I may do some beefing up and save for the V8. Right now just working on fixing the interior and minor mechanical things. Ie, new radiator, voltage regulator, batt. cables, gaskets, trim parts, etc.
Sat down over the weekend with some parts cataloges, at the moment about 1k in parts and pieces.
Doug, I was there once. I had a 6 in my 1967 Coupe and went thru 3 motor mounts and 1 trans mount in high school, my dad teached how to change them too after the first one! LOL
Up date, putting in a new windshield ( orig. is wiper scratched on pass. side.) with new front and rear window gaskets. Figured if I am pulling it out might as well put in a new one. New radiator is at the parts store waiting for me to pick up, looks like sat. morning is going to be busy. Ended up ordering a few boxes of parts, just need some warm weather to work on it...LOL.
well got the new windsheild in, replaced the rear seal. tore out the old dash pad and have that cleaned off. Got a new set of insturment bezels, replaced all the dash bulbs. Just need to get the radio plate welded in and get the dash set up to be painted, Then start putting things back together on the inside. Need to take a weeks vacation to work on it, not enough daylight hours at this time to get much done.
New radiator is still in the box, been fighting with a leaking tire, had it to the shop twice now, inner rim is rusted and leaks all around, they sanded it and hit it with sealer, hope that holds now.
