Mustang suspension
Old Jul 24, 2012 | 11:33 AM
shelby4sb's Avatar
Mustang suspension
I am restoring my 1965 mustang coupe and I am curious as Ti what everyone has done with their suspension. I am going to make the car daily driver and it will have a 302 engine. Thanks for your help!!
Old Jul 25, 2012 | 01:07 PM
HOSS429's Avatar
legacy Tms Member
just a good stock rebuild of components should suffice .. they made zillions of these cars and the stuff worked good .. of course you could step up to a modern rack and pinion system if you like but they are very pricey ...
Old Jul 26, 2012 | 10:43 AM
shelby4sb's Avatar
That sounds great thanks for responding! I am doing rust repair and body work is next which shouldn't be too extensive
Old Jul 27, 2012 | 12:29 PM
les's Avatar
les
That's what everyone says shouldn't be to much next thing you know months have gone by and it is still ongoing. I also upgraded my front coils to 1" drop performance ones. After pulling the original coils off it sat at the same height but a bit stiffer. Also recommend changing the leaf springs as they are more then likely very tired.
Old Aug 18, 2012 | 08:07 AM
Lenor's Avatar
I'm installing a TCI front suspension. It's pretty sick. If your handy with a plasma cutter, grinder and welder, I deffinetly recommend. I'm actually installing in my 68 fastback today... Your can do a YouTube search on Stacy David's gearz v8 interceptor. He installs one on a 68 cougar.
Old Aug 26, 2012 | 09:31 PM
shelby4sb's Avatar
How would I go about getting a mustang II front suspension for my 65?
Old Aug 26, 2012 | 10:32 PM
Forkmachine's Avatar
I bought a kit from John at Opentracker Racing Products. He was a big help in deciding what I needed and I even worked it out so I could pick it up when I was at Laguna Seca for vacation rather than paying shipping. He also helped greatly with installation assistance when I got confused a few times.
http://www.opentrackerracingproducts.com/products/
I replaced the front upper and lower control arms, springs, shocks, and strut rod bushings. I did standard parts but I did buy rollerized spring perches. It corners like it is on rails and before it handled like crap, partially because the front right shock was completely gone...
John also sold me a template which was used to drop the upper control arms down by about 1", known as the Shelby drop, which provides better grip by providing better geometry/alignment for modern tires.
I also put in a monte carlo bar and a beefy strut tower brace from CJ Pony Parts.
It still rides pretty rough as it did before on the crappy roads where I live, but it takes spirited corners like a champion. I did choose some sportier/stiffer springs. I planned to do quite a bit of stuff to the back suspension but haven't got around it since I got into modding my new toy...
I would definitely give John at Opentracker a call. He can put a package together for you or even just give you very experienced advice on what you need for how you want to use the car.
Old Aug 27, 2012 | 05:09 AM
Lenor's Avatar
You can call TCI directly and they could help you out with where to buy. These suspensions will make your car drive and handle like a new modern car. They're pretty simple to install with the step by step instructions, provided your handy with a welder.
Old Aug 27, 2012 | 12:01 PM
Lenor's Avatar
If your based out of California USA your in luck. You won't have to pay much on shipping. I live in Toronto Canada, shipping was a *****!
Old Aug 27, 2012 | 02:42 PM
shelby4sb's Avatar
What was the overall price that you paid if you don't mind me asking? Thanks!
Old Aug 28, 2012 | 11:42 AM
Lenor's Avatar
I paid $3300 delivered to my door.but that also included power rack and pinion steering, powder coated A arms, adjustable spring coil overs,and engine mounts. I bought it last year during Christmas, when they had there year end sale... Wait for the sales to begin, if your interested. They're always having promotions on...
Old Sep 7, 2012 | 08:43 PM
shelby4sb's Avatar
How do you tell if you have a 9 bolt rear end on a 65 or 67 mustang? Thanks!
Old Sep 11, 2012 | 04:31 PM
matcox83's Avatar
Not to be a smart a**, but Google "how to identify a ford nine inch." I just tried it and there are a lot of good answers already out there. I forgot to search this forum, it's probably already here as well.
Old Sep 11, 2012 | 05:50 PM
shelby4sb's Avatar
Thanks I appreciate it lolol
Old Sep 17, 2012 | 10:26 PM
shelby4sb's Avatar
I am considering installing a roll cage in my 65 mustang coupe any thoughts? Has anyone done this and has pictures? Thanks!
Old Sep 18, 2012 | 05:50 AM
HOSS429's Avatar
legacy Tms Member
if you can remove all the nuts from the center section with a ratchet and socket it will be an 8 inch .. a nine inch will require a boxed end wrench on a couple of nuts ..
Old Oct 5, 2012 | 08:53 AM
shelby4sb's Avatar
Who has the best prices for a mustang 2 front suspension? Or does anyone recommend a different front suspension to put on my 65 coupe? It's going to be a daily driver. Tell me what you have done to your front suspension! Thanks
Old Oct 21, 2012 | 07:53 PM
Frequently-Sideways's Avatar
Unless, your looking to put a engine that's too big to fit without going the Mustang II route the aftermarket as well as the Shelby A arm drop shouldn't be ruled out.
I've seen these vintage car perform at track events with Ford suspension, Total Control Products, Global West and others. Unless space for your engine is the reason I'd find where your budget leads you!
Old Oct 24, 2012 | 03:47 AM
RW1967GTA's Avatar
This would be my recommendation as well. For a daily driver, anything more than a Shelby drop with GT or 620 springs with a larger sway bar and a set of quality gas shocks is overkill. I like rubber bushings over polyurethane. Poly performs better, but oh the squeeking! On a daily driver, it might drive you nuts.
ustabawannab
Aug 5, 2015 08:32 PM
killaz05
Jul 24, 2015 08:49 AM
Jul 21, 2015 10:32 AM
Ecostang
Jul 11, 2015 09:06 AM
