Master Cylinder Rebuild VS New
Old Jul 6, 2013 | 04:46 PM
AJRogue3's Avatar
So the duel master cylinder I ordered was the wrong one, and the correct one is on back order. I was thinking of just getting a rebuild kit and fixing the old one. It is leaking at the engine side firewall. Will this work or am I just putting a brand aid on a bullet wound?
Old Jul 6, 2013 | 06:48 PM
I would go with a new unit if I had the choice. That said if you take the old one apart and all the seal surfaces look alright then a rebuild kit should do the trick.
Old Jul 6, 2013 | 07:11 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Depends. If it's just a leaking seal then a rebuild will work fine. If the metal is cracked or scored to the point a seal can't "seal" then you will be wasting moolah
Old Jul 6, 2013 | 07:42 PM
We used to always rebuild them as long as they weren't pitted. But be sure to lightly hone it before you throw in the new seals.
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
BigHoss
Sep 21, 2015 10:03 AM
bconboy
Sep 18, 2015 08:18 AM
bconboy
Sep 10, 2015 02:31 PM
