Looking for some advice from more knowledgeable people than me
Old Jul 16, 2014 | 05:28 PM
ER12883's Avatar
Originally Posted by fstbck70
WCZ T corresponds to a 66 mustang with an 8.8 rear end with 3.50 gears. That's what I found out. You can just google "WCZ T axle code" and click on the first result and see for yourself
I'm honestly scratching my head a little. I found the same thing: 66, 8 3/4", 3.50. I THOUGHT 65-68 were either 8 or 9 inch. It is possible that the source o the two sites we looked at is the same, and incorrect. Please set me straight!
Old Jul 16, 2014 | 05:36 PM
ER12883's Avatar
Originally Posted by MateJJ
What's the consensus on cherry bombs... The car sounds nice... It's got a good Rumble without being obnoxious.... I wonder how she will do on inspection? Seems strange... I think I'm reading those numbers right... I guess it was changed out when the engine was upgraded... As far as a leak goes... Every joint down under therefore like that as well... Looks like someone was very liberal with spray lube... Lol Anyway nothing seems to be leaking., but I'll keep an eye on it... Joe
If the exhaust works and is in decent shape, I would leave it if you're happy with it. I don't now about performance vs other exhaust types.
I would wipe down everything that appears wet and see if it reappears, just so you know.if it is an issue, I think that can be serviced without removing the axle - just disconnect the driveshaft, and remove the third member. Getting the crush washer just right is apparently tricky, so either lots of YouTube instruction, or take it to a shop. But honestly, if it winds up being a very slow weep, I wouldn't worry too much about it until you have reason to take things apart, just keep an eye on fluid level.
Old Jul 16, 2014 | 05:48 PM
fstbck70's Avatar
My guess is unoriginal. But I was also unaware that the 8.8 was available that early
Old Jul 16, 2014 | 09:43 PM
MateJJ's Avatar
Good Tip! I'll clean her up and start looking for a leak...
Upon furthur inspection and looking at the tag closer this is what I came up with...
the Top Line is WCZ F ...and the Bottom Line is 3 0 5EC 911
...BTW - that makes a lot more sense so I'm assuming it is the stock rear end. So, that leads to my question...is a stock 8.0 rear end OK with a 302?
Old Jul 17, 2014 | 10:31 AM
Paris MkVI's Avatar
Five bolts on all the wheel hubs? Disc or drum brakes in front?
Old Jul 17, 2014 | 01:01 PM
MateJJ's Avatar
Five bolts, with drums all around...Must be new or something because she stops really well, but I do see a disc brake in my future!
Rear Tire
Front Tire
Cobiecane
Oct 23, 2015 08:44 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
mabupa
Sep 23, 2015 12:17 PM
