late model alternator
Old Dec 6, 2004 | 09:34 AM
BLAKE's Avatar
What are my choices when going with a latemodel alternator? I'm installing an '85 5.0 and keeping the serpentine setup. Since I need a new alternator anyway, which should I go with? One-wire, stock '85, 3G (likely out of my price range, but I still want to know what's out there).
Any wiring advice or links you may have would be great.
Old Dec 6, 2004 | 09:48 AM
GT350Clone's Avatar
For one-stop shopping, you simply can't beat PA Performance. I used their 3G upgrade kit for the 87 GT that Coupe now owns. Quality stuff - good direction, and they KNOW what they're talking about.
Now, so I won't be accused of only giving the "hi-$" approach, you CAN do the same upgrade with a little reading, splicing, soldering, and searching. Here's some "alternate" (pun intended ) resources:
http://www.bcbroncos.com/techtips1.html
http://www.bronco.com/technical/upgrades/EFI_swap.shtml
http://www.fordmuscle.com/archives/2001/03...nce/index.shtml
Old Dec 6, 2004 | 09:50 AM
Jay's Avatar
Jay
I've used Powermaster and cheap models off eBay (one wires). I have found the Powermasters are the only ones that tend to work right the first time, you get what you pay for. Too bad I eBayed the 1 wire I had a couple months ago, that was setup for V or serp.
As far as the 1 wire there's nothing to it other than running 1 wire to the (+) side of the solenoid. 130amp is good if you are running a number of electric items like ignition, fans, fuel pump, etc.
If you skimp on the alternator you will more than pay back for it on other parts, time, etc.
May 3, 2026 05:42 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
Sep 30, 2015 07:02 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
