Headlights turn of and on????
Old Feb 24, 2014 | 08:07 PM
davidpee's Avatar
I have a 1965 mustang coupe and my headlights go out after a minute being on and when they go off it make a little ticking noise. Not sure what is causing this but don't wanna drive it in the night because I don't know when they'll start goin off and on. Need advice on what to do thanks
Old Feb 25, 2014 | 11:23 AM
Tyoung68's Avatar
What kind of head lights do you have?
Old Feb 25, 2014 | 11:33 AM
Joeywhat's Avatar
Sounds like it could be a relay failing. Check the relay in place for the headlights, and replace if need be.
Old Feb 25, 2014 | 11:57 AM
ER12883's Avatar
I was thinking relay or even a loose connection tripping a relay or something.
Old Feb 25, 2014 | 02:58 PM
davidpee's Avatar
Going to try checking connections since they're the original wires already had to replace engine wire harnesses. I've read about it being the switch is there any way to check if it that?
Old Feb 25, 2014 | 03:08 PM
Joeywhat's Avatar
You can use a digital multimeter to test the switch. I'm not sure how you would check a relay, I think you'd have to give it power from somewhere to thoroughly test it.
Old Feb 25, 2014 | 03:13 PM
davidpee's Avatar
Where would I find the relay?
Old Feb 25, 2014 | 03:35 PM
Joeywhat's Avatar
I really have no idea, I know next to nothing about first gen mustangs. If no one else chimes in, you can follow the headlight wires back to it.
Old Feb 25, 2014 | 04:04 PM
davidpee's Avatar
Okay thanks for the help
Old Feb 27, 2014 | 12:08 PM
matcox83's Avatar
There is a circuit breaker built into the switch. After 50 years, it is weak and can't carry a load. You need a new switch.
lakersfreak
Jun 13, 2022 12:29 AM
trackpack13gt
Jul 25, 2017 05:29 PM
ricky1728
Feb 11, 2016 07:25 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
