Floor Mount E-Brake Handle
Old Oct 25, 2004 | 08:55 PM
GT350Clone's Avatar
I do like that one Bryan posted in the console!!! Note the Shelby gauge pod too!
Old Oct 26, 2004 | 10:27 AM
bnickel's Avatar
did you notice the guages inb the dash too? that was the main reason i saved that pic. that was pretty cool and original i thought, may have to try to do something like that myself one of these days
Old Oct 26, 2004 | 10:36 AM
bnickel's Avatar
Originally posted by Jay@October 25, 2004, 8:55 PM
Pretty hot setup you found. Let's get more details on that one for the project...
it looks to be the exact same lokar unit that cloney has. as far as any other info the pic is really all i have, but i can tell you that on a 69/70 console there is much in those areas to cause any interference. if we used a 69 console we might be able to make the e-brake sit back a little further by doing away with the cig lighter in the console, it is setup so that the console box is angled from top to bottom at th front where the lighter is, which might give us some room to move the brake back a little bit getting us a cleaner look. the only obstacle in the way if we did that would be the rear bracket as it sits right under the front of the box, but that could be modified rather easily and a new bracket made that attaches at the rear of the console.
Old Oct 26, 2004 | 02:06 PM
Stroked66's Avatar
Top side looks GREAT
But what bout underneath? Does it use some type of bridge connector like the stock one so the handle will activate both rear brakes?
What bout cable routing around the DS?
Cummon BOB! Inquiring minds need to know these things
Old Oct 27, 2004 | 06:56 AM
GT350Clone's Avatar
Haven't had a chance to work on the cables, as I've been sick the last few days, and don't feel like crawling around on the concrete floor...
I'm planning to using the original 65 connector with a new adjusting bolt running from the handle clevis to the connector.
PLENTY of D/S clearance - more than the stock setup, since the cables now run up at the top of the tunnel. I'd say there's 3" of clearance now, whereas there was 1" before.
Old Oct 27, 2004 | 09:38 AM
Mberglo's Avatar
Cloney,
Very nice mod. It's a functional subtle change that doesn't stick out like a sore thumb.
NC14GT
Sep 10, 2017 04:47 PM
samjluck
Oct 26, 2015 05:17 PM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
