Fastback trunk tension rod
Old Jan 15, 2005 | 06:21 PM
AGShelby's Avatar
My lid has been off for about 3 months while I repainted the inside of the trunk. Upon re-assembly, I found that the trunk tension rod will pop out on the passenger side when the trunk is closed. If my memory is correct, there was once a small metal piece that went over the rod to keep it in place.
I have looked at 2 other fastbacks and there is nothing on the rod (both parts/junk cars). Is my memory correct? If not, is my hinge just too worn and needing replaced?
Thanks -
Steven
Old Jan 15, 2005 | 07:09 PM
silverblueBP's Avatar
IIRC, there should be one of those push caps that goes on the end of the rod. When I re-installed the lid on my car the cap would not stay on so I threaded the end of the rod and dbl nutted it B)
Old Jan 15, 2005 | 09:32 PM
GT350Clone's Avatar
Yep, Silverblue has it right - there's a pushnut on the end...
Old Jan 16, 2005 | 05:50 AM
AGShelby's Avatar
Thanks for the help - I was not sure if a pushnut would handle the stress. I thought about drilling a hole and putting a key - but will try the pushnut first.
SG
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 24, 2015 08:15 PM
TMDM
Sep 24, 2015 07:00 PM
AdPock
Sep 15, 2015 08:58 PM
Sep 10, 2015 12:44 PM
