Engine/engine bay cleaning
Old Mar 8, 2011 | 07:56 PM
Mustangmike66's Avatar
Can anyone tell me the best way to clean my engine and engine bay? What product works best? My car is a 7 out of 10. With the engine and bay done it could be a strong 8.5. Any help?
Old Mar 8, 2011 | 07:58 PM
mike05gt's Avatar
I use Simple Green
Old Mar 9, 2011 | 08:10 AM
Big Poppa's Avatar
Originally Posted by mike05gt
I use Simple Green
Me 2,
Old Mar 13, 2011 | 06:03 PM
OKLACOP's Avatar
I'll recommend Simple Green as well. I get some stuff at Wal Mart called "Mean Green" that is a generic for Simple Green. Works just as well for about half the price.
Old Mar 15, 2011 | 10:02 AM
ChrisM's Avatar
When I had my '69 Sportsroof, I typically cleaned the engine compartment once a year in the spring. I would run the engine til it got warm (not hot.) Then pull the air cleaner, distributor cap and plug wires, and cover the carb and distributor head with plastic bags held in place with a rubber band.
Next, I would spray the engine and engine compartment with Foamy Engine Brite cleaner (available at any auto parts store) - it usually took two cans - and let it sit for 10 minutes or so. Then spray the whole thing down with a garden hose. Use an air hose (or reversed shop vac) to blow off any standing water. Finally, wipe any remaining water up with paper towels. Now you can detail the radiator hoses, touch up paint dings, etc.
Last step is to clean the air cleaner, distributor cap and plug wires by hand. GoJo or Simple Green work well on those. Then reassemble everything and run the engine a bit to let it heat dry any hidden water spots.
Hope this helps!
Road_Runner
Sep 2, 2024 04:46 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
CoyotePremium13
Sep 23, 2015 06:45 PM
