Darn Oil Pressure
Old Jan 1, 2005 | 02:53 PM
Paul's Avatar
Smile
Hi there--
I've been having problems with the GT using oil. I know I have one, possibly two bad rings. Ok, the latest is that at a constant speed, the oil pressure will drop from 3/4 across the gauge where it usually rides to between 1/4 and 1/3 across the gauge. Just changed the oil yesterday with 10/40. The waggling pressure makes me nervous.
Ok, as I see it, it could be
  • Bad Sender
  • Bad Gauge
  • Bad Wiring
  • Bad Instrument Panel Voltage Regulator
  • Dying Engine (I don't want to think about this one.)
What order would you tackle these? I'm thinking of checking the wiring, getting a new sender and see what that does. Then the Volt. Regulator. Then getting an aftermarket gauge to see if mine is bad.
If I get an aftermarket gauge, electrical or mechanical? I'm no wiring ninja, so it'd need to be simple.
How would you attack this? (Yes, I know I need to rebuild, but with a 2 year old, that isn't in the cards yet.)
--Paul
Old Jan 2, 2005 | 01:31 PM
Paul's Avatar
UPDATE: Wiring seems ok. Put in a new sender and now, at hot idle, the needle stays at between 1/3 and 1/2 across the dial. Am going to take it for a drive and see how she does.
Sheesh. Sometimes I wish I had idiot lights!
--P
Old Jan 2, 2005 | 08:47 PM
Paul's Avatar
UPDATED UPDATE: The pressure held mostly solid at about 1/3 to, occasionally, 1/2 of the sweep of the needle. (I'm taking this as a bad sender.) I noticed that the oil pressure gauge and the fuel gauge--which reads 1/8 of a tank low--wiggle a tad in unision. This, I'm guessing, is a bad Instrument Panel Regulator.
I gonna order a new one and rebuild the dash cluster while I have it out. Might was well. Maybe I can solve the riddle of the never moving volt-meter in my cluster!
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
