Blinkers
The blinkers in my 67 turn on, but don't blink. When I bought the car about 8 months ago the blinkers were fine and gradually they started blinking sparadically...then about a couple months ago they stoped blinking. I flip the lever and they turn on on the dash, and outside the car....why are they not blinking...any suggestions?
More than likely you have a poor or many poor ground connections. The flasher blink because of the current load in the circuit, high resistance slows that flow way down. The flasher has a thin metallic strip that is heated by the current flowing thru it, when it gets hot enough it bends and breaks the circuit. When it cools it snaps back and the process is repeated.
As a test you can switch the hazard flasher and the turn signal flasher, if the turn signals work the flasher is bad. Then check the lights, check for water getting into the fixtures and corroding the bulbs and sockets.
Well that really depends on who or what may have messed with the wiring over the years but you should be able to locate it somewhere inear the center. Do you know what it looks like?
Originally posted by JazzCow@May 23, 2005, 7:49 PM
I looked under the dash for the flasher unit and I must be stupid because I had trouble finding it...where is it?
Good luck!
Turn signal flasher is located on the right side of the steering column under the dash. The four way flasher unit is more than likely on the passenger side of the dash to the left of the glove box.
puma1552
4/23/14 12:41 PM
