bench test brake master cylinder
Old Dec 13, 2004 | 08:41 PM
69Mach1's Avatar
i have a 69 fastback and i am redoing the brakes. i took the master cylinder out and i am trying to bench test it to make sure it is working.
this car is equiped with discs up front and drums in the rear. when i push the lever in fluid shoots out of the 2nd opening (furthest from firewall) and nothing comes out of the first one (closest to firewall). there is a sucion from the first one but nothing comes out. is this normal?
after i do the master i am going to take out the brake booster and check that out. is there a way i can check that out also?
Old Dec 14, 2004 | 11:35 AM
66HertzClone's Avatar
The gyser of fluid is a normal function, it is called compensation. Did the master work on the car? Without a gage to measure the pressure produced I can think of no way to check the function of the master unless it was installed on a car.
Old Dec 14, 2004 | 04:26 PM
69Mach1's Avatar
i figured it out on my own. the big resivor is for the front brakes, smaller one is for the rear. i have to keep pumping the master to see if fluid pumps out of both ports, if not, new master.
Old Dec 14, 2004 | 07:30 PM
GT350Clone's Avatar
You can't generate enough pressure with a bench test to properly check a master cylinder. If in doubt, just replace the thing!!! It's ONLY YOUR BRAKES! Not a great place to cut corners.
Old Dec 14, 2004 | 08:29 PM
69Mach1's Avatar
yea i am going to hook it up to the car when everything goes back together and hook up a pressure gauge and check it out that way...as of now i am going to put it back only bc i only took it off to paint it and replace some of the old lines.
Old Dec 16, 2004 | 10:32 PM
Paul's Avatar
I agree. Don't save money on tires, seat belts and brakes. I finally got rid of my suicide-singe cylinder and dropped in a two chamber MC. I couldn't believe the garbage that was at the bottom of the fruit jar. I think I saw what was left of Jimmy Hoffa.
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
