5 Lug Adapters???
Old 9/12/07 | 06:45 PM
1966L6's Avatar
5 Lug Adapters???
OK I know these are a bunch of newb questions i ve been asking but i searched this on the site and come up with next to zilch on this subject so.
Is anyone now or have in the past used 4 to 5 lug adapters on their 64.5-66?
I have found some adpters but it says you have to use a high offset wheel with it like a front wheel drive type wheel.I would like to run 16" or 17" wheels.
Has anyone been down this road?
Old 9/12/07 | 09:57 PM
x21's Avatar
x21
It was a thought I was looking into myself, for my 68 with the I-6 & 4-lugs. Could only find the early 5 lug- to - late 5 lug adaptors though. Even found fox 4-lug to 5 lug adaptor and early 4 to late 4 adaptor as well.
Is there a specific reason you would want a classic 5-bolt pattern (5 x 4.5)? Or did you want a late model 5-lug (5 x 4.25)? Or will any pattern (4 or 5 lug) work as long as you can get 16/17 inch wheels?
found some references-
http://www.alliedracingwheels.com/patternref.html
http://www.mustangmonthly.com/techar.../classics.html
Finding the 'right wheel' for your early pony depends on how much effort you may want to put into getting your bolt pattern compatible with the wheels you want/like. Putting adaptors is the easiest way to get the right bolt pattern, but as you mentioned, an undesireable backspace. Other options include switching to a classic 5 lug pattern (replacing spindles & the 7in rear), so you can follow what the MM article suggested more easily.
More from another forum that I frequent
6 Cyl Mustang
tire size/circle pattern/back space/hub bore
14x6/4x4.5/4.000/2.516
15/6/4x4.5/3.500/2.950
15x7/4x4.5/4.500/2.950
8 Cyl Mustang/Cougar/XR7
14x6/5x4.5/3.500/2.516
15/6/5x4.5/3.500/3.180
15x7/5x4.5/4.500/3.180
I hope any of this helps.
Old 9/13/07 | 02:55 AM
1966L6's Avatar
Well the reason im looking for adapters is i cant find any 16" or 17" wheels with a 4 lug to fit my car.I found one set of 15" and they were 230 each and didnt look that great.Im just want to expand my choices.
I would like to have a bullit type wheel.
Old 9/13/07 | 05:15 AM
x21's Avatar
x21
new school or old school bullitts? Either way, they are based off of Torque Thrust wheels- http://www.newstalgiawheel.com/wheel...ubcat3=1011100 which are available in 16"
If you want to weigh upgrading to an original 5 bolt (4.5") pattern, you can also get better braking options over your current setup. Plus no wheel spacers would be needed as there are many options for a classic 'V8' mustang- GTwheels, styled wheels, AR series, etc- therefore you dont have to worry much about backspacing, so long as you can find a rear axle that would work with your car.
As of right now, consider that classic Datsun wheels should also have the same bolt pattern and backspacing as our ford 6 mustangs. A few other sixers I know have also gone with Weld draglites as well.
Old 9/13/07 | 12:33 PM
1966L6's Avatar
Do they make draglights in a 4x4.5 15"??
Old 9/13/07 | 04:49 PM
x21's Avatar
x21
Check em out-
http://store.summitracing.com/egnsea...4294755962+115
and
http://store.summitracing.com/egnsea...2&autoview=sku
Old 9/14/07 | 03:59 PM
1966L6's Avatar
Hey Thanks
Old 9/18/07 | 09:16 AM
Sharp's Avatar
If you going to be racing this car I would recommend you don't use 4 to 5 lugs adapters. They are not as strong as converting to car over to 5 lug.
lsingggh310
Ecoboost
2/7/16 01:26 PM
yabutt
10/23/15 02:05 PM
10/2/15 02:00 PM
Evil_Capri
9/11/15 09:39 AM
oldnjguy
9/10/15 03:39 PM
