289 stalling
Old May 14, 2011 | 04:52 PM
Pistol's Avatar
289 stalling
I have a 66 coupe with the stock 289. Have never had an issue with it, ran great until a couple days ago it started stalling on acceleration (when cruising), sputtering and even cutting off after it has been driven for a little while. Sounded like a bad fuel pump/filter issue so I replaced both but is still happening. Could it be the carb? Any ideas on where to look next would be helpful.
Old May 14, 2011 | 04:55 PM
Pistol's Avatar
Sorry, should add that it is an automatic as well.
Old May 14, 2011 | 04:59 PM
HOSS429's Avatar
legacy Tms Member
if you still have the original ignition you may try a new condensor and make sure the points are opening .. then go to the coil ..
Old May 14, 2011 | 05:16 PM
Pistol's Avatar
I had the car tuned up a couple of months ago with new plugs, wires, etc. And have also put a new coil on since then as well.
Old May 14, 2011 | 05:19 PM
HOSS429's Avatar
legacy Tms Member
still check the points setting then go to the carb accelerator pump ..
Old May 14, 2011 | 05:46 PM
Yeah I've had my 4.9 stutter on acceleration. It would reboud pretty quick, but the accelerator pump wasn't spraying so there was always a momentary lag.
Old May 14, 2011 | 11:05 PM
Pistol's Avatar
Just found a pretty good crimp in the fuel line, don't know how it got there but gonna try replacing that and see if that helps.
Old May 14, 2011 | 11:22 PM
That's a good thing to do. However, since a carb has a reservoir (float bowl), that would only affect the refill time, right? Not the immediate lag when you hit the peddle.
Old May 19, 2011 | 08:25 AM
codeman94's Avatar
Timing?
I used to have a problem where if i was at a standstill and floored it... it would immediately die. I advanced the timing a little and it went away.
Uofmrampage
Aug 2, 2022 02:55 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 23, 2015 03:21 PM
Mustang65bob
Sep 21, 2015 11:30 AM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
