1970 Mach 1 Mustang 351c head identification*
Old Apr 17, 2017 | 04:49 PM
Jonathan351c's Avatar
Hi guys, I'm new to mustangs and could use a bit of advice. I'm ready to put some work into my dad's old 1970 mach 1. I'm having trouble identifying the heads on the 351c as I can't find a casting code on them. All I can see is the date code 9h19 as that it's a 4v head. Any ideas on what I've got here? Pictures attached Thanks a lot.
Attached Thumbnails 1970 Mach 1 Mustang 351c head identification*-20170417_140822.jpg   1970 Mach 1 Mustang 351c head identification*-20170417_140800.jpg
Last edited by m05fastbackGT; Sep 8, 2023 at 08:31 PM. Reason: Moved To 1964 - 1970 Mustang Forums
Old Apr 17, 2017 | 06:39 PM
ElkGroveFordGuy's Avatar
I dont think there are any other casting numbers.
Just date codes.
On another note in your picture it looks like the lifter bosses in the block are cracked!
Is that the case or just a shadow in the picture?
Old Apr 17, 2017 | 06:40 PM
HOSS429's Avatar
legacy Tms Member
if the engine is original to the car you will have a good set of the closed chamber heads .. i`m not sure when they switched to the open chamber style to lessen compression ..1972 i think .. they should have a casting date like a D0 something meaning 1970 .. D1 would be 1971 etc ..you have one of the best engines ford ever made .. they just made them too late and too few of them .. imagine if Carroll Shelby had a 351C to play with in his cobras or 65 Shelbys ..
Old Apr 17, 2017 | 06:48 PM
Just date codes.
I think that's just the picture I accidentally used the hdr function.
Old Apr 17, 2017 | 06:59 PM
[QUOTE=ElkGroveFordGuy;7012987]I
A bit more background on the engine. In 1980 my father had the engine balanced, blueprinted and had the compression ratio dropped from 12:1 (stock I think) to 9:1 as his plan was to go twin turbo. The engine never made it back into the car. My father has since passed away and the car is mine to fix up. I dont think I want to go turbo as I already have a turbo datsun. I was hoping that 351c could be built up for around 450-500hp range. But first I need to figure out what I'm working with.
Old Apr 18, 2017 | 03:32 PM
Here's something that looks troubling. Seems to be a hole in the engine block up front near the lifter bosses. Looks like it was almost drilled open!?
Old Apr 18, 2017 | 04:54 PM
HOSS429's Avatar
legacy Tms Member
one allows oil to drain back into the oil pan .. the other allows oil to splash into the timing chain area ..it looks like your dad did not run the engine .. i guess you dont know what kind of cam is in there .. take it all back apart and start from scratch .. find a hotrod article on how to build a 500 horse cleveland .. it will not take much .....
Old Apr 18, 2017 | 05:12 PM
Thanks I'm on my way
Attached Thumbnails 1970 Mach 1 Mustang 351c head identification*-img_20170418_160753.jpg   1970 Mach 1 Mustang 351c head identification*-img_20170418_160705.jpg
Old Sep 8, 2023 | 08:33 PM
m05fastbackGT's Avatar
Michael Oliver
Feb 25, 2017 08:07 AM
Topnotch
'10-14 Special Editions and Aftermarket Mustangs
67
May 30, 2011 04:50 PM
beneman
Jan 21, 2005 12:41 PM
TMSBrad
Oct 11, 2004 07:00 AM
