1967 Rear
Old Aug 21, 2004 | 01:49 PM
red302pony's Avatar
Does anyone know what a '67 289 2 barrel auto had as rear gears? Thanks.
Old Aug 21, 2004 | 01:57 PM
charles's Avatar
email mustang monthly
Old Aug 21, 2004 | 02:08 PM
67shelby's Avatar
Rear gears were options, so we can't tell you. You need to contact Ford and get a 999 report or contact Kevin Marti at Marti Autoworks and order a report for your car which would be on record. The Marti report will cost you depending on how fancy of a report you get. The 999 report from Ford is free, but will just present what data they want to give you. The number for the 999 report is in Mustang Monthly each month.
Typically, a stock 289 C code would probably have a 2.80, 2.83 or 3.00 gear I would guess.
Old Aug 21, 2004 | 02:34 PM
jpony645's Avatar
Or..... Check to see if your fender VIN and door VIN match. If they do you could check the data plate on the driver's door and decode the information there using this link.
http://www.fomoco.com/mustang-vin-decoder.shtml
The reason they have to match is that a lot of times the driver's doors have been replaced and may not have the correct information for your particular car.
Old Aug 22, 2004 | 11:00 AM
GT350Clone's Avatar
With the 289-2V and auto, a 2.80:1 was standard. The 3.00:1 was optional, along with limited-slip.
3.25, 3.50, and 3.89's were available with the hi-performance V8s.
2.83 & 3.20 were available with the 6-cylinder.
Old Aug 23, 2004 | 07:44 AM
jpony645's Avatar
WTF kind of answer is that?
Old Aug 23, 2004 | 08:33 AM
LMan's Avatar
Im sure its a 2.80.....thats the gear in 99% of C-code 289/C4 cars.
But find out for yourself! Jack up the rear, mark the driveshaft, and spin the wheel......
________
Silvanna cam
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
JonathonK
Sep 8, 2015 05:11 PM
