Auto/Man Trans Gear Ratios for V6 & GT ?
Not sure if this has been printed somwhere or addressed in the forum before, but I have looked through all the various '05 related specs & info I have collected (plus Brad's extencive 2005 data page) and do not find these "specs" listed anywhere.
I'm not asking for AXLE RATIOS ... this is already mentioned in various places ...
V6 Auto & Manual and GT Auto ... 3.31:1
GT Manual ... 3.55:1
I want to know the ratios of 1st, 2nd, 3rd, 4th, & 5th of the Transmissions themselves ... curious as to IF they have changed from prior years. Since the Auto box is a new for 2005 5-Speed, how do the ratios comare to earlier Mustang 4-Speeds ??
For example ... when the new 1999 model came out, the 3.27:1 Ratio Rear Axle became standard across the board (prior V6's had 2.73:1, GT's had 2.73:1 or 3.08:1). This was a big change for the V6, so Ford also changed the manual trans ratios to better work with the 3.27 rear axle.
'94-98 V6 T5 ... 1st: 3.35:1, 2nd: 1.93:1, 3rd: 1.29:1, 4th: 1.00:1, 5th: 0.73:1
'99-04 V6 T5 ... 1st: 3.35:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.68:1
'94-?? GT T5 ... 1st: 3.35:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.68:1
'99-04 GT T5 ... 1st: 3.37:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.67:1
'94-?? V6/GT Auto ... 1st: 2.40:1, 2nd: 1.47:1, 3rd: 1.00:1, 4th: 0.67:1
'99-04 V6/GT Auto ... 1st: 2.84:1, 2nd: 1.56:1, 3rd: 1.00:1, 4th: 0.70:1
** Data is from Super Ford November 1993 and Corral.net "1999 Mustang Unveiling" article from September 1998.
I've never kept as tight of tabs on the GT's, so I don't know if Ford kept the same ratios from '94-98 or if there was a change when the 4.6L came out in '96.
From the November Motor Trend article, they mention "close 1-2-3 gearing" on the new 5-Speed Automatic, but don't state what the ratios are !! A final drive ratio of 2.35 is also mentioned ... divide this by the 3:31 axle and that gives us the 5th gear / overdrive ratio of 0.7099:1. Other than this, I have seen no mention of actual transmission gear ratios.
Doug
Doug
From http://www.velocityjrnl.com/jrnl/2005/vmd2941sp.html
V6 Tremec T-5 : 3.35 / 1.99 / 1.33 / 1.00 / 0.68, 3.15 reverse, 3.31 final
V6 5R55S (auto) : 3.22 / 2.29 / 1.54 / 1.00 / 0.71, 3.07 reverse, 3.31 final
GT Tremec 3650: 3.38 / 2.00 / 1.32 / 1.00 / 0.68, 3.38 reverse, 3.55 final
GT 5R55S (auto) : Same as V6 auto.
Rando
8/25/21 11:12 AM
CiniZter
25
4/28/16 05:41 PM
