Auto/Man Trans Gear Ratios for V6 & GT ?
Old Oct 4, 2004 | 10:42 AM
orange3.9stang's Avatar
Not sure if this has been printed somwhere or addressed in the forum before, but I have looked through all the various '05 related specs & info I have collected (plus Brad's extencive 2005 data page) and do not find these "specs" listed anywhere.
Old Oct 4, 2004 | 12:36 PM
SC67Stang's Avatar
I remember reading this somewhere but couldn't find it when I needed it.
Old Oct 4, 2004 | 01:00 PM
Madhouse's Avatar
327 gears in both V6 auto and manual, and in the GT auto
355 in the GT manual
...I think...
edit: whoops, I guess you meant trans. gears, not rear gear ratios...
Old Oct 4, 2004 | 01:46 PM
I'm not asking for AXLE RATIOS ... this is already mentioned in various places ...
V6 Auto & Manual and GT Auto ... 3.31:1
GT Manual ... 3.55:1
I want to know the ratios of 1st, 2nd, 3rd, 4th, & 5th of the Transmissions themselves ... curious as to IF they have changed from prior years. Since the Auto box is a new for 2005 5-Speed, how do the ratios comare to earlier Mustang 4-Speeds ??
For example ... when the new 1999 model came out, the 3.27:1 Ratio Rear Axle became standard across the board (prior V6's had 2.73:1, GT's had 2.73:1 or 3.08:1). This was a big change for the V6, so Ford also changed the manual trans ratios to better work with the 3.27 rear axle.
'94-98 V6 T5 ... 1st: 3.35:1, 2nd: 1.93:1, 3rd: 1.29:1, 4th: 1.00:1, 5th: 0.73:1
'99-04 V6 T5 ... 1st: 3.35:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.68:1
'94-?? GT T5 ... 1st: 3.35:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.68:1
'99-04 GT T5 ... 1st: 3.37:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.67:1
'94-?? V6/GT Auto ... 1st: 2.40:1, 2nd: 1.47:1, 3rd: 1.00:1, 4th: 0.67:1
'99-04 V6/GT Auto ... 1st: 2.84:1, 2nd: 1.56:1, 3rd: 1.00:1, 4th: 0.70:1
** Data is from Super Ford November 1993 and Corral.net "1999 Mustang Unveiling" article from September 1998.
I've never kept as tight of tabs on the GT's, so I don't know if Ford kept the same ratios from '94-98 or if there was a change when the 4.6L came out in '96.
From the November Motor Trend article, they mention "close 1-2-3 gearing" on the new 5-Speed Automatic, but don't state what the ratios are !! A final drive ratio of 2.35 is also mentioned ... divide this by the 3:31 axle and that gives us the 5th gear / overdrive ratio of 0.7099:1. Other than this, I have seen no mention of actual transmission gear ratios.
Doug
Old Oct 4, 2004 | 01:54 PM
Indystang's Avatar
Looks like its similar to shifting from 2nd. gear to 4th. in a manual. No wonder it dogs out
Old Oct 4, 2004 | 02:33 PM
Gene Jockey's Avatar
From http://www.velocityjrnl.com/jrnl/2005/vmd2941sp.html
V6 Tremec T-5 : 3.35 / 1.99 / 1.33 / 1.00 / 0.68, 3.15 reverse, 3.31 final
V6 5R55S (auto) : 3.22 / 2.29 / 1.54 / 1.00 / 0.71, 3.07 reverse, 3.31 final
GT Tremec 3650: 3.38 / 2.00 / 1.32 / 1.00 / 0.68, 3.38 reverse, 3.55 final
GT 5R55S (auto) : Same as V6 auto.
Old Oct 4, 2004 | 02:38 PM
Thanks, that is what I was looking for !!
BRAD ... this info should be added to the timeline or FAQ INFO !!
Doug
Rando
Aug 25, 2021 11:12 AM
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
