My wife
Bridget was so excited when these arrived that she asked if she could
install them. I agreed on one condition: that she write the review. So
here it is, in Bridget's words:
I
really like them; I think they add a lot of personality. They make
"MUSTANG" on the door sills stand out much better. In fact, the
letters are barely noticeable without them.
The
decals were really very easy to install. You need to be sure to get
the letters on the sill place really clean because any little bit of
dust or dirt will cause bumps. The directions say wet the letters.
This means wet the letters on the panel of the car not the sticker
letters. I found it to be very effective to fill the indentions up
with water and use your finger and a pair of small point tweezers. Let
the sticker float in the water and get it in place by moving it with
the tweezers. Then hold it down with the tweezers and using a paper
towel, absorb some of the water out. The letter should be stuck down
and you can continue to the follow the directions and run over the
letters with your finger wrapped in a paper towel. You need to be sure
to press on the letters when running over it with the paper towel so
that the letters end up smooth but be sure not to slide the letters.
When going over letters with the hairdryer, I recommend putting your
finger by the letter, so that you can feel when the plate starts to
get too hot. When the letters are still hot from the hairdryer you can
use the tweezers again to push or pull at the letters where it might
not fit just like you want it.
Overall, I think this product is great. It adds a lot for a small
amount of money. I think it is important to know that this product
comes in several different colors and will fit any 2005+ Mustang, not
just cars with IUP.
