What noise is this?
Old Today | 07:06 PM
FoilpaperIQ's Avatar
What noise is this?
Hey ya'll, can someone help me identify this noise? For context I have a cat code at the moment, I'm not sure if it's a blown cat. When I go through 2nd and 3rd gear I hear the same rattle as in the video attached. When I'm in neutral and give it throttle to mid rpms, the rattle intensifies after letting off the gas. Clutch pedal in, it reduces, clutch pedal out it rattles at mid rpms. It comes from around the trans/cat area so I'm not sure what it could be. Car has 150k miles, the noise has been consistent for about 5k miles, hasn't gotten much worse or deadened. I immediately thought clutch, pilot bearing/tob, or input shaft bearing, however when driving, other than it being an old trans and sometimes catching, I have no slipping and no problems. I'm truly stumped here.
File Type: mov
Old Today | 08:01 PM
05stangkc's Avatar
The Analog Admin!
Check Out The Post 4 in Below Link Here! Might Work For You!
Does Sound a Bit Like A Busted Cat Though!
Get Er Up on Stands With a Long Piece of Wood Away From Car & Listen To Cat!
https://themustangsource.com/forums/...p-link-550939/
Fhbrumb
3/24/20 06:22 PM
04stang523
1994-2004 V-8
3/11/14 09:58 PM
99stang
9/20/07 09:32 PM
netminder009
1994-2004 V-6
6/13/04 02:51 AM
Quick Reply: What noise is this?
