BCM problems
BCM problems
Hello, I have a 2009 mustang GT with automatic transmission.
I recently purchased a used BCM because the old one had water damage which was causing ac and power mirrors problems, I hooked up the new BCM and the ac and mirror problems were fixed but I could not shift the car out of park, break lights turn on, and when reconnecting the old BCM it works again, I was wondering if it's a faulty BCM or do I
need to get it reprogrammed? All part numbers and Delphi match up and all fuses on new one are good.
Thank you
Thank you
The Analog Admin!
Received 3,179 Likes
Probably Came out of a Stick Car! Likely Need To Reprogramed. See Info This Thread To Gleen Some Info!
Good News It Is The Correct Box!
Especially Shop Manual PDF's
https://themustangsource.com/forums/...5/#post7082475
Kc
Kc
