05-09 vs 10-14 Auto Trans Shifters
Old 10/20/21 | 01:49 AM
BRD's Avatar
BRD
Does anyone know if the shifters are interchangeable between the different S197 versions? Say one from a 10-14 in to a 05-09 car? The T handle in my 08 just looks kinda blah to me compared to the next version. I'm sure I could find one in a junkyard and swap it if the cable/linkage hookups and bolt down are all the same. Anyone know or tried it before?
Old 10/20/21 | 09:01 AM
houtex's Avatar
I personally do not know if they are completely compatible. The easier thing to do is just go to a bone yard like you say and see what happens.
But I also personally do know that with a dremel, drill, hammer, and maybe some bondo or a welder or something, I can *absolutely* stick a '67 truck column shifter on Awesome and make it work. So I'm bettin' this thing would be really easy with those tools.
Don't be skeert. Worst case should be it don't fit and you put it all back, unless'n you sit there and start to actually dremeling, then you gotta make it fit, way to go you.
/Dangit, now I wanna 5 speed on the tree. I mean, who else would have one on a S197, right?
//Supplemental of course. Think paddle shifters only stupider.
Old 10/20/21 | 09:41 AM
Bert's Avatar
05-10 versus 11-14 have different transmissions, so I doubt the shifter would be compatible, but not sure
BRD (10/20/21)
Old 10/20/21 | 10:52 AM
akdoggie's Avatar
Shifter is not compatible. It sits in a slightly different position and the console around it is different also. Been tried before. Surprisingly only a few things swap from 09 to 10 models.
Door speaker covers, sunvisors, outside mirrors, wheels, tires and underpinning, but interior and body are off enough for things to not swap cleanly.
There is a link on this forum about this swap. I haven't been here in a few years, but the link was there before. A guy tried to do the full interior swap. Not a good fit in his pictures.
BRD (10/21/21)
Old 10/20/21 | 10:02 PM
BRD's Avatar
BRD
Twas just a thought. I still might grab one at a junkyard one day and see if it can be modified to fit, I might get lucky, who knows
Bert (10/21/21)
Old 10/21/21 | 03:23 PM
houtex's Avatar
That's the spirit. To the Dremel-cave, Mod-man!
Bert (10/21/21)
Old 10/21/21 | 04:58 PM
akdoggie's Avatar
https://themustangsource.com/forums/...onsole-536920/
The following 2 users liked this post by akdoggie:
BRD (10/21/21), VGMStudios (10/23/21)
Old 10/23/21 | 05:37 PM
VGMStudios's Avatar
My car is a '07. If you want to use the shifter from a '10 you'll need to change the center console from that year.
I put in the shifter from a '10 but then changed the **** from a '14 cause I didn't like the look of it.
Old 10/23/21 | 05:56 PM
BRD's Avatar
BRD
And the e brake handle from what I gather. Thanks for the info. A lot of trimming to make the console to fit, how much effort was it to actually hook the shifter and e brake up?
Old 10/24/21 | 10:34 AM
VGMStudios's Avatar
Yes the parking brake as well.
Hooking up the shifter wasn't that bad. IIRC I had to go under the car to connect it. But I could be wrong as I did this in 2014.
BRD (10/25/21)
Old 10/29/24 | 10:35 PM
Cherrythe3v's Avatar
Im currently trying to swap a 2013 shifter into my 3v with a 6r80 swap and im using the Quick6 tcm, thought you swapped the 13 shifter but it really is a 2010 with a 13 ****…
Old Yesterday | 01:05 PM
m05fastbackGT's Avatar
2010-2014 shifters are all compatible with the same *****... However, they are not compatible with the older 2005-2009 shifters/transmissions...
Old Yesterday | 02:25 PM
05stangkc's Avatar
The Analog Admin!
Also The Early Shifters on The S-197 Had a Round Metal Shaft The **** Went on And Those Were Easy To Swap *****. The Later Ones Went Fubar When You Took The **** Off Sometimes! On My 05 I Swapped Black **** To IUP ****. Then The Slide Went South & Replaced Whole Shifter With IUP Setup.
EARLY SHIFTER
EARLY SHIFTER
LATER SHIFTER
LATER SHIFTER
outlawmack
3/5/13 10:32 AM
2010MustangGT
5/9/10 02:58 PM
Quick Reply: 05-09 vs 10-14 Auto Trans Shifters
