Track Related Mods
#541
Well my batter died and will not recharge. So time for lightweight battery! Went with the Odyssey PC680. Fires right up with no issue. And 17 lbs lighter!! Now I can eat that extra taco for dinner
#543
Currently a Corvette Owner!
#545
A nice track related mod that I wanted to share (if you weren't aware) is our S197 jacking rails ... great for jacking at, before or after the track!
https://www.steeda.com/steeda-s197-m...ing-rails.html
TJ
TJ
#546
Got the car back with ARH LTH w/catted H-pipe installed. Today I switched out the stock strut brace to the BMR version and installed StopTech slotted rotors on all four corners. Test drive had some unexpected results. Hard braking resulted in front tire lock up and rear dancing, with increased rear bite I might go to lower friction pad to decrease rear bias. I think the brake system over powered the tires but that could be because they weren't up to temps yet. All in all I think the changes were improvements. Any recommendations or advice on the brake scenario I described are welcomed?
#548
Originally Posted by dmichaels
It's heat related most likely. Try it again with tires up to temp
How are the headers??
#549
Originally Posted by SGwick
morning dmichaels, the headers are amazing. Great build and quality materials. They give the right amount of grunt (especially above 3k rpm) for me sound wise and aren't obnoxious (loud for no reason). I still have my stock resonators and gt500 axel backs so it's pretty tame but the ARH roars when I need it :-)
#550
Hey SG, sweet setup. I'm jelly of the new headers! I love the LTH sound on our mustangs. Enjoy!
As for brakes, I remember getting rear end wagging left to right when I had too little rear bias, and when one side of the rear was not installed correctly. The rear piston was pushing on the peg on the bottom of the pad, it wasn't sitting flush against the pad.
#551
#552
I just finished an event at Grattan. It was a good "brushing off cob webs" exercise and car control via shuffle steering looking back at the camera footage.
Next up is Gingerman, which is tough on tires and brakes. Speaking of brakes, after Gingerman I expect my XP10s up front to be toast. And 8 days after it's Mid Ohio, which has one huuuge brake zone. I'm curious to try other pads. So I will be swapping to Raybestos ST43 pads up front while keeping XP8s in the rear. I'll post impressions after.
#553
Drilled exhaust tips and test fitted exhaust silencers (incase my exhaust is too loud for LRP). Hopefully they work
#554
Whaaat? That's crazy, I hope you don't have to tame your beast!
I'm not a fan of super loud cars myself, but at the race track?? C'mon! -- This message goes out to LRP management.
Good luck, I hope you can keep it breathing, and have fun. I'm off to Gingerman tomorrow. I need to settle down the car/driver prior to Mid Ohio next week. The 200+ degree corrections I was doing at Grattan last weekend will not fly at Mid O.
#555
Man you're busy! Good luck tomorrow and then MidOhio.
Noise ordinance is 86-89db at LRP on restricted days (more frequent)
#556
Received 1,547 Likes
So that's a BMR strut brace, eh? I have one that looks just like it, bought it used from a guy in Connecticut, he told me he had it fabricated locally . . . don't know why he would lie about that; strange . . .
#557
So did you ever find yourself wondering if 3mm of front pad lining is enough for the next event? Well, with XP10s I found out the answer is NO. They actually did fine in the 7 sessions, but fell apart right after. I had to change them on the road side 120 miles from home. The friggin backing plates bent too. Glad I pulled over to change them out, otherwise the rotors would probably be toast too.
So now I've got Raybestos ST-43 in the front. We shall see how they do at Mid Ohio next week.
Also the Hankooks have gotten significantly grippier, and I backed off on how hot I go into corners which helped too. I find the grip of the tire is contributing to more speed scrub in the corners, so I find that I'm on the throttle way before the apex now too.
SGwick (7/3/17)
#558
is this normal?
So I finally swapped out my Raybestos ST43s pads to my street setup (now Akebono Ceramic street pads) and as I'm swapping them out I noticed this gouge in the pad. I noticed some on at least one pad of each caliper, with this being the worst.
Is this normal?? I have had these pads in for 3 weeks. 1 track days and ~600 street miles.
#559
#560
maybe you got a stone lodged in between at some point?
