Custom Vanity Personalized License Plates & Brackets /Delete Brackets Threads Over The Years With Members Custom Plates
Ideas for front license plate bracket holes?
Old Jul 29, 2013 | 12:25 PM
97GT12's Avatar
3M makes flexible filler for bumper covers. Just use that and touch it up. If done correctly it shouldn't look much different than the factory dimples. I did this to fix a small nickel sized scrape in the rear bumper cover of my '97. Could barely tell anything happened and that was much bigger than a screw hole.
Another option would be a couple of set screws. Screw them in, paint the heads. Or cut the heads off the bracket screws and drive them in flush and paint. (might require making a slot in the remaining part of the screw to have something to drive them with.
Old Jul 29, 2013 | 01:32 PM
Bucko's Avatar
Originally Posted by shiazv@gmail.com
if u ever plan to do stripes just leave them alone... vinyl stripes will go over the top n cover it... looks fine on my car.
After awhile, the sun will cause the stripe to sag into the hole slightly. If you go the route of covering the hole, put some plastic filler in the hole and sand it smooth; the rough paint will be hidden by the stripe, and you won't have a dimple in the stripe from the hole.
Old Jul 29, 2013 | 01:34 PM
Bucko's Avatar
Originally Posted by Dan S.
that moment when your realize you spent 10 minutes using your phone writing a pointless message on a forum...
Such as this one?
Old Jul 29, 2013 | 09:26 PM
Coyote5-0's Avatar
Originally Posted by Bucko
Such as this one?
mostly.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
robjh22
14
Nov 1, 2015 11:28 PM
pretender
2011 - 2014 GT/CS
Aug 26, 2015 02:57 PM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
