67' Shelby Project
Service Manager
Service Manager
Typically it takes HOURS to remove an upper and lower cowl section and it requires drilling out hundreds of spot welds....
However, while the car is solid...it was redone MANY, MANY years ago from the appearance of things and while all the work looks as though it was done properly from everything we have seen, someone took a shortcut on the cowl panel and it was brazed in about a dozen places and then caulked with household tube and tile type caulking. This caused some rust in the edges and the result of what they did meant the cowl was not securely attached and while we dug out the caulking we noticed the entire cowl moving....in a little over 30 minutes we had the entire upper and lower cowls out of the car. This would normally take HOURS to accomplish. This goes to show that you should not rely on appearances...we knew something was up though from the brushed look around the cowl under the hood...so I knew someone had been in there before.
We are going to mount the car on a rotisserie and soda blast everything...this well give us a completely clean shell were we can address anything needed and properly install the new cowl panels.
There were no 67 Shelby convertibles sold to the public. (I think there was one made by Shelby that was later turned into a 68). So are you going to make it look like a 67 Shelby or 68 Shelby?
I guess I was looking for brand recommendations. I've been reading CornerCarvers.com and although they have a lot of good options, I'm not sure I want to cut a car up and I intend to drive the car on the street. I'm not willing to sacrifice for that extra nth second on a road coarse, but I would like to be able to take it once or twice a year.
I may dive in headfirst and buy a dynacorn body and build it exactly the way I want. I'd rather spend $50k and do that than buy someone elses heap they are sick of dumping money into. I want to plan it all out in advance to minimize costing myself time/money.
Thanks,
Frank
Service Manager
Thanks Paul,
Thanks,
Frank
Thanks,
Frank
While there are a lot of knowledgeable people on Corner Carvers I find it to be a bit unfairly biased at times..mostly because if someone recomends something different than the masses they are either banned or severly chastized...that site is more like a 3 ring circus at times. One of my customers just simply wanted to share a video of his Kenny Brown Stage 2 prepped Mustang and they not only banned him for it, they attacked and crashed his server in spite....very childish if you ask me. I've been a member there for a few years now but never go there anymore after witnessing that behavior. Seems that along with those that DO know a thing or two...you have an equal amount of childish people that make it an unfriendly atmosphere for those looking to get into it or educate themselves.
I have everything for this car on paper suspension wise right now and as soon as we progress a little further I will let you know exactly where we are headed. In the end it's up to John but he is still weighing in on some of his plans for the car.
Service Manager
That is correct and the 1 convertible that was made is sitting in a Museum. The car will be a '67 Shelby replica....with only 1 being made, all the more reason to make it a '67 to have something different. Aside from that John prefers the '67 appearance over the '68....I feel the same way myself.
I do too, although its hugely popular, Ive never been a fan of the styling for '68, with the '68 GT500KR's front fogs.
Service Manager
If anyone is interested that is following along....the engine and transmission from this car are for sale...John will not be using either. The engine is complete as pictured with a Performer intake and Edelbrock carb and it is spotless inside...ran perfect...also has an electronic distributor, Motorsport valve covers and '93 5.0 HO shorty headers. It appears as though this car was originally restored in the very early 80's and this was probably a Ford Crate engine. The block is dated 1979 and the heads are dated 1978...it is a 302. The Transmission is the original C4 and appears as though it was rebuilt in the past and while it worked the fluid was still red but not crystal clear red so I would recommend freshening it up prior to install. Both engine and trans are at my shop...pickup only. $700/OBO on the engine and $75 on the transmission.
Looks a like a solid, well optioned 67 vert ! I have just seen the post of the fire....... sorry about that. But with this one, the bad times are behind and the good ones are coming.
Succes
Geoffrey
Succes
Geoffrey
Service Manager
It's baking soda and completely environmentally freindly....but this isn't california and therefore we are not regulated by those "types". Besides, the construction company service bay next door has more things for tree huggers to worry about with occasional oil spills and pressure washing big rigs than to worry about what little we do here.
Service Manager
I have a Motorcycle to "stick it to the man"....that Prius is just SO ugly I couldn't even ride in one as a passenger!!! Why is it that EVERY hybrid or "green" car is the ugliest thing on the planet....almost like the tree hugger designers don't have a lick of taste at all!
Aside from that my SVO gets 27-31mpg (highway) depending on how much you stay out of the throttle.
