1971-1973 Mustang Member Tech & Restoration Discussion
What Piston Type for 351c, Flat Top or Dished/Domed? Need Help!
Old Jul 5, 2012 | 03:31 PM
Swords's Avatar
Post What Piston Type for 351c, Flat Top or Dished/Domed? Need Help!
hey everyone, I am in need of some expert advice. I am rebuilding my 351C and am currently in the market for some pistons. It had flat tops in it when i took it apart. This engine is going back in my 1971 fastback which will be mostly a street car and and occasional track car.
Any suggestions? Should i stick with flat top or look for a dished/domed piston? would I have any clearance issues if i went with domed?
Old Jul 5, 2012 | 09:38 PM
Swords's Avatar
forgot to put this, I have a '72 block with '70 open chamber 2V heads
Old Jul 6, 2012 | 10:19 AM
HOSS429's Avatar
legacy Tms Member
go back with replacement flat tops as anything with a dish will give a really low compression ratio .. you can get a 4 barrell intake to fit the two barrell heads .. go with a mild cam as the heads will flow ok for 351 cubes .. put on some headers ..and this motor will be a good candidate for some nos ...
Old Jul 6, 2012 | 07:11 PM
terry thimesch's Avatar
I just rebuilt a 351c. Had dish pistons put in flatop. Was about 10.5 compression. I wouldn't go to dome uwouldnt b able to use pump gas.
Old Jul 6, 2012 | 07:19 PM
I am putting in a new wiring harness in my70 mustang.using aamerican auto wire harness.I am pretty satisfied so far. The tech people have been pretty good.has anyone used this one or the painless one?
Chris71grande
Aug 9, 2013 02:32 PM
Nate98stang
1994-2004 V-8
May 27, 2011 08:56 PM
kjacobson351
May 7, 2010 08:53 AM
kjacobson351
May 11, 2006 12:14 AM
