Sponsored by:
Sponsored by:
Performance pack Winter tires/wheels
Old Nov 23, 2015 | 07:18 AM
drumstix5001's Avatar
Just got a good deal on a 2015 GT with performance package and now that it is getting colder, I need to get a set of winter tires/wheels to a set of winter tires. I just bought 2 used Michelin pilot alpin in 255/40r19 to fit the front, now I need to find two good options to fit the rear as cheaply as I can. My two questions are, does anyone know what the best options might be for the rear winter tires? Also, would the front 255/40r19 tires be able to fit on the rear without issue? I am thinking for the winter set I can just make all the tires/wheels the same size to make it easier, plus I'd be able to rotate them in the winter.
Any advice will be appreciated
Old Nov 29, 2015 | 11:33 AM
PA-Fatboy's Avatar
Go with Blizzak's. I run them in the winter and they are fantastic for me. All 4 are same size. I mounted them on a set of rims to make it easy for me to swap a between summer and winter tires. I did get the package from Tirerack.com.
Old Nov 29, 2015 | 12:18 PM
Joeywhat's Avatar
Make sure the rear tires are similar in performance to the others. Mixing tires with very different grip profiles will lead to you being in a ditch.
Old Nov 30, 2015 | 07:16 PM
5.M0NSTER's Avatar
255/40-19 winter tires fit from 8.5 to 10" rim, so you'll be good with all 4 of the same size. No need to go staggered in the winter, that's actually worse for your rear end traction.
Old Dec 2, 2015 | 07:55 AM
Are you putting them on your stock wheels? If so, the rears are 19x9.5 - you can't rotate them.
Old Dec 2, 2015 | 07:54 PM
I bit the bullet and bought new wheels from American muscle so I can just swap them out myself
Old Dec 2, 2015 | 08:01 PM
I mm an effort to keep costs down I went used winter tires and got two Michelin pilot alpin in 255/40r19 for the front and two Pirelli sottozero in 275/40r19 for the rears. Id have preferred with going with 4 of the same size but I couldn't find a set of 4 winter tires in the 255 size.
kponypower
Jun 17, 2020 07:17 AM
dblhelx
Dec 29, 2015 04:16 PM
GeoWett
Sep 30, 2015 06:40 AM
DEPUTY62
Sep 12, 2015 11:12 AM
