Sponsored by:
Sponsored by:
indicater help needed
Old Sep 15, 2018 | 11:45 AM
captain greg's Avatar
​​​​​I am wondering what is needed to get my indicaters in the rear to flash in a sequential manner ( the three lights to flash one at a time toward the side energized) I have a 2017 GT
i read some pla e it's a module that plugs in ?.
Old Sep 15, 2018 | 12:53 PM
Dr Plastic's Avatar
They all do that. At least my 2016 does it straight from the factory
Old Sep 15, 2018 | 12:54 PM
woody24's Avatar
Turn signals are sequential to begin with. Any other sequential lights (Braking, Emergency) would require an addon like this one. https://www.americanmuscle.com/raxio...ness-1014.html
Old Sep 15, 2018 | 02:13 PM
frank s's Avatar
Must be some kind of difference between US and export models, eh? The plug-in modules worked good on earlier Mustangs. Could be they'd work on yours.
Old Sep 15, 2018 | 02:48 PM
Thx guys no ours don't do that, any links to a module that plugs in!
Old Sep 15, 2018 | 06:21 PM
area5179's Avatar
I just bought a set from CJ Pony Parts but they may not work on your vehicle. I see your location as Cape Town which I suspect means your in South Africa. Unfortunately, All the tail light kits I can find are for US spec vehicles ONLY. The set I bought was $80 (USD) so you mcan purchase a set and see if they work but I can't guarantee that they will work on your vehicle. Here is the link if you want to give them a try: https://www.cjponyparts.com/diode-dy...-2019/p/STL15/
Old Sep 15, 2018 | 09:49 PM
houtex's Avatar
You are in South Africa, yes? As such, I believe you are required to have the amber turn signals. Therefore your Mustang has the factory 'european spec' tail lamp assemblies, which are clear instead of red tinted, and have an amber light in them to indicate a turn, no sequencers.
This video shows someone doing the reverse of what you are asking about: Exchanging his red assemblies with the sequentials to the clear and amber:
And in there you'll see it's a bit messed up, in that the inner two red brake lights come on, then the amber end turn signal lights come on, in sequence of sorts, but basically instead of a smooth 1-2-3, you get a 12--3 sort of sequence.
I'm not sure your car would do the sequencing at all, but if those people can do what they did, you can probably get a sequencer kit for a 05-09 and figure it out...?
...I'd just leave it. Besides, it'll give the police an excuse to pull you over.
But still, you asked and so here a the link to *a* kit that you can splice with. I don't know if you can get it from there, but it's a start. Again, it's iffy if at all you can do this. You'll likely be pioneering a solution. And/or you may need to get US Spec tail lamp assemblies in the first place to do it at all...
Hope that helps!
Old Sep 20, 2018 | 03:03 PM
wanted33's Avatar
https://www.youtube.com/watch?v=X0UT-EZBMvo
Hope that helps!
Bingo, that's what I was thinking. It may be best that you check with your local Law Enforcement to make sure you are not violating any motor vehicle, or safety laws.
azoufan
05-09 Exterior Modifications
Jul 5, 2006 07:16 AM
SonicBlueV6
V6 Performance Mods
Jan 26, 2005 08:15 PM
originalplaid
05-09 Interior and Audio Mods
12
Jan 19, 2005 08:29 AM
troxGT
1994-2004 V-8
19
Jan 9, 2005 09:58 PM
