Grinding brake pads\rotors - 2019 GT
I'm currently in the process of 'breaking in' my new 2019 GT with just 850 miles on the clock. Recently I've noticed there's a slight grinding coming from the front brakes (front right particularly) when under moderate to heavy breaking - the kind when the lights change just as you approach and you need to stop. The grinding occurs just as the car is slowing to a complete stop. It doesn't occur under normal braking around suburban streets.
Not sure if this is just a case of the brakes 'bedding in' or if there's a problem developing. Anyone else had any experience with this?
Have you done an actual "bedding-in"? I'd have to guess any minor anomalies in brake manufacture/tolerances would be eliminated by such a procedure. Of course, if it gets worse, you might need to apply some corrective action. Brakes on these cars are really subject to some violence, and are entitled to complain a bit.
yeah, I think an actual bedding procedure might be a good idea . . . scraping sound is not "normal" so I hope it will go away with more use, if not I'd take it back to the dealer
Google should be able to find the bedding procedures for you
woody24
9/4/18 08:42 AM
