Sponsored by:
Sponsored by:
Grinding brake pads\rotors - 2019 GT
Old Sep 16, 2019 | 10:49 AM
BakeryHill's Avatar
I'm currently in the process of 'breaking in' my new 2019 GT with just 850 miles on the clock. Recently I've noticed there's a slight grinding coming from the front brakes (front right particularly) when under moderate to heavy breaking - the kind when the lights change just as you approach and you need to stop. The grinding occurs just as the car is slowing to a complete stop. It doesn't occur under normal braking around suburban streets.
Not sure if this is just a case of the brakes 'bedding in' or if there's a problem developing. Anyone else had any experience with this?
Old Sep 16, 2019 | 05:50 PM
frank s's Avatar
Have you done an actual "bedding-in"? I'd have to guess any minor anomalies in brake manufacture/tolerances would be eliminated by such a procedure. Of course, if it gets worse, you might need to apply some corrective action. Brakes on these cars are really subject to some violence, and are entitled to complain a bit.
Old Sep 17, 2019 | 06:20 AM
Bert's Avatar
yeah, I think an actual bedding procedure might be a good idea . . . scraping sound is not "normal" so I hope it will go away with more use, if not I'd take it back to the dealer
Google should be able to find the bedding procedures for you
Old Sep 30, 2019 | 06:31 PM
Any updates on this
Old Sep 30, 2019 | 07:05 PM
BakeryHill's Avatar
Originally Posted by Glenn
Any updates on this
Still there slightly but only under heavy braking and only for the last few rotations before it stops.
wario's construction
Oct 3, 2012 03:16 AM
Ford Ferret
Sep 15, 2009 07:37 AM
05retro
Jan 31, 2007 10:15 PM
instigator311
Jul 2, 2006 09:40 PM
