Brake upgrade
Brake upgrade
Hey I wanted to upgrade my brakes to 6 piston brembos currently I’m on the base gt brakes..are the rotors on the car now compatible with the brembos calipers and pads? Or do I need to buy a new kit and switch out the whole system? It’s a 2017 btw
The Brembo rotors are 15 inches to match up with the 6 piston calipers. Next you will need to source the correct front wheels to clear the larger brakes. This upgrade is not a cheap parts change out. Good luck!
