2015 Roush Active Exahust ??? -any info- ???
I have been watching for this exhaust system on the Roush website. Just recently, they added the quad tip exhaust that is "ROUSH Active exhaust Module compatible" but have not specified when the module will be available, or their suggested price. I will keep checking as it gets closer to April since I would like to have it in hand before the car arrives. The exhaust can be seen here.
Link is for the fastback version, there is also a convertible version available.
We were told early April these are going to be released. As with anything new, add a couple weeks just to be safe.
We will be doing some pre orders on this. Give us a shout. The active portion of the exhaust will not be available until sometime in June/ July.
Do you know if this is how it is going to work?
I have read that the quad exhaust that will be available soon will be the passive model so you can still change the sound, just have to install or remove the block off plates. Then once the active module is available, you just replace the block off plates with that.
That's the same info I have. I know the active portion will be available anywhere from May to July and will be fairly simple to install.
