Fast Lane News, Tech, and Advice from one of the top teams in Mustang road racing, Rehagen Racing. General road racing discussion welcome!
Engine problem, need help
Old Jan 27, 2015 | 10:55 AM
NJragtop's Avatar
I had a spark plug blow out of the head and break the coil mount. Installed a new plug with a sleeve but it won't start. Any thoughts on the cause? Timing chain? Broken rocker, push rod, valve? Still get compression. Have not yet removed the valve cover? What do you suggest to do to diagnose the problem.
Old Jan 28, 2015 | 12:17 PM
5.M0NSTER's Avatar
What year/model/engine?
Might want to post this under warranty and service issues. You might get more replies there.
Old Jan 29, 2015 | 07:07 PM
is it back firing at all when you are trying to start it. Reset the fuel cutoff switch just for the fun of it. Turn the key on and see if you hear the fuel pump kick on
Old Jan 29, 2015 | 07:27 PM
Well he said pushrod, so I'm guessing there is no fuel cutoff switch and the fuel pump is mechanical.
Old Jan 30, 2015 | 09:56 AM
well in that case I guess I was just running up my post count!
Old Feb 4, 2015 | 01:06 AM
GottaHaveIt's Avatar
maybe the plug was replaced without being torqued down right I had one pop out tip broke inside head , stopped engine immediatley put a clear bag over plug hole had my son start car ,electrode or tip shot out into bag before scouring up the cylinder, lucky day i'd say.
Mpaps
Oct 11, 2017 08:06 PM
mustangsally_
Sep 18, 2015 05:35 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
Evil_Capri
Sep 11, 2015 08:39 AM
