what should i get for front tires? 275 or 255? to go with my rear 305's
Old May 6, 2015 | 11:38 AM
DarrenGT's Avatar
I have received my Mickey T 305/35/20 tires but the 275/35/20's are backordered. They have 255/35/20's in stock though, so i could replace the them on the order. what would be better ? wait it out for the 275's or swap in the 255/35/20's instead?
Old May 6, 2015 | 11:40 AM
CCTking's Avatar
Wait on the 275's
Old May 6, 2015 | 10:34 PM
ElkGroveFordGuy's Avatar
275's, bigger is better!
Old May 7, 2015 | 04:19 AM
TripleBlack14's Avatar
275's if you can stand the wait. What width wheel are you running up front?
Old May 7, 2015 | 05:48 AM
David Young's Avatar
Go with 275's. 255's aren't wide enough, even for the v6 Mustang
Old May 7, 2015 | 06:08 AM
CCTking's Avatar
Thats what she said
Old May 7, 2015 | 07:53 AM
Originally Posted by CCTking
Thats what she said
It ain't about size...it's how well you use your shifter!!!!
Old May 7, 2015 | 08:19 AM
Speedwagon's Avatar
I went with 275/35/20 Nitto
Old May 7, 2015 | 08:31 AM
DarrenGT's Avatar
ok good. i'm waiting for the 275s
Old May 7, 2015 | 09:23 AM
dmichaels's Avatar
Also recommend this. With 305's, you would probably be good with 285 fronts if they fit. The narrower the front tire with the wide back tire will create more and more understeer.
I run a square setup and like the handling that's resulted in. Boss 302 runs staggared but also runs larger rear sway bar. I have done rear 275 front 255 and it would tend towards understeer vs neutral or oversteer.
Anyways 275 front should be fine
Old May 7, 2015 | 09:26 AM
CCTking's Avatar
But if you little tires and cant drive a stick... We're sorry lol
Old May 7, 2015 | 09:41 AM
DarrenGT's Avatar
no problems with rubber or stick here
Old May 7, 2015 | 10:42 AM
Then I guess the moose get a little nervous up by you, huh?
Old May 7, 2015 | 11:52 AM
CCTking's Avatar
But does your car have trouble starting?
Old Jun 21, 2015 | 03:44 PM
dohc97's Avatar
Just saw your post. I am looking at the same tires to replace my 255/35/20 and 285/30/20 Nitto.
Have you gotten your MT tires? How is it?
Old Jun 21, 2015 | 04:14 PM
DarrenGT's Avatar
I do have my wheels and tires on now. The offset on the alcoa style wheels doesn't allow enough clearance on the 305's when lowered so i adjusted my suspension up 3/8" to allow them to tuck in when suspension compresses.
I have no complaints about the mickeys at all so far. road noise seems normal, handling is good, excellent traction. i've driven some rain and again no issues.
Old Jun 21, 2015 | 04:24 PM
dohc97's Avatar
The offset on my HRE wheels are 35 front and 45 rear. Am I going to be okay with these tires then? Have any pics of the new wheel/tire combo?
Old Jun 21, 2015 | 04:31 PM
DarrenGT's Avatar
my wheel offfsets are 25 and 37. I don't know much about offsets though. i think you should be ok since your HRE's offsets will keep your wheels tucked in a few more mm than mine. I won't be able to lower my car any more with these rims.
MRGTX
2007-2009 Shelby GT500
Jan 2, 2024 04:30 PM
dohc97
17
Aug 14, 2015 07:12 PM
