UCA noise??
UCA noise??
Got a UCA installed today and I am hearing a bumping/popping noise when at low speeds when I brake or accel. Anyone know why this is happening or what I can do? Thanks in advance
Sounds like something isnt tightened all the way,you shouldnt get those sounds with poly bushings.I have the Roush uca and its quiet as stock with no wheel hop.
I have the same problem. J&M with the stock mount. I'm told it's because the stock bolt and the bolt holes are different sizes so that's most likely where your clunking is coming from.
This Hotchkis UCA uses a Heim Joint style bearing. So the noises you are hearing is normal. FK Bearing sells polyeurathane boots to go over the spherical bearing to help quiet it down.
Rando
8/25/21 11:12 AM
