Suspension poping
![Angry](https://themustangsource.com/forums/images/icons/icon8.gif)
I just installed a full eibach lowerein kit. Car handels amazing, but i noticed lately while coasting down the drive way are when entering a parkinglot a pop sound coming from the rear suspension. It sound like the shocks which are eibach as well i cecked everything out all looks good and is snug. I guess my question is could it be the shocks. Please shoot me any ideas i'm on the verge of just buying new ones andchaning them out to see what happens??
Yes i replaced the shocks, struts, springs, and sway bars it was part of the eibach kit i ordered. Is this Normal? will it mess anything up ? its only when coasting over small bumps..
I didn't have a lift eaither had it up on jack stands wheni tightened them.. So the adjustment need to be made at the wheels rite? Would jacking it up by the rear diff substitute the suspension being under a load?
thanks for the help. i'll give it a try when i get home from overseas
Please don't tell me you are going to lift it by the rear differential and that's it. I'm sure you won't work under a car with only a jack under the rear diff.
Put the jack stand under the axle tubes while you are at it.
Also I'd love to hear what a poping rear end sounds like. Actually I wouldn't. I'm sure his rear end sounds the same as mine only a little older.
Evil_Capri
9/11/15 08:39 AM
