Steeda Sport Springs Rates?
i can't find any rates on these springs, steeda is on here can you please tell us the rates on these springs for the 11-13 mustangs?
http://www.steeda.com/store/steeda-s...t-springs.html
Here is the size of these sway bars compared to the stock sway bars bellow.
http://www.steeda.com/store/steeda-f...d-mustang.html
Front 34.92 mm Rear 22.22 mm
Stock.........Front Sway/Rear Sway/Front Spring/Rear Springs
Base GT.....34.6 mm....24mm.......123 lbs.......156 lbs.
Brembo......34.6 mm....24mm.......131 lbs.......167 lbs.
Boss 302....34.6 mm.....25mm.......148 lbs......186 lbs.
Laguna Sec.34.6 mm.....26mm.......137 lbs......191 lbs.
Is this what your looking for....
555-8206 Steeda Ultra Lites - 195lb front, 175lb rear
555-8215 Steeda Sport Springs 200lb front, 175lb rear
555-8220 New Steeda 05-12 GT Convertible sport springs 200lb front, 190lb rear
555-8245 - New Steeda Comp Springs Boss 302 and GT 225lb front, 195lb rear.
Thanks TJ
Thanks TJ
Thanks TJ
Thanks TJ
Thanks TJ
Thanks TJ
i was going to order the Sport spring set but since the rear stock gap is about 3" and the front gap is about 2 3/4" i would prefer to order the Ultra lives in order to drop the rear more... but seeing that the Lites drop the front 1 1/4" instead of 1" i decided not to get those either, so I'm stuck in a limbo, hoping there is a way to order 2 front Sport and 2 rear lites, I'm willing to pay a little extra for the special order.
Please let me know
Yes, but we are not going to guarantee how that is going to sit. Ride height are based on matched components. Start mixing and matching and you might not get the results that you intend.
Pricing will be in the pallpark of a normal set of springs. Call 1-800-950-0774 to place your order with one of our sales professionals.
TJ
TJ
TJ
TJ
thank you
I've read in a few places those numbers for the Sport springs are not correct.
The Ultra Lites are definitely FIRMER than Sports.
9/24/15 08:15 PM
