Sidewall choices for Brembo/Track-Pack Wheels
Dear Fellow Stangers,
To those of you went wider tires on stock brembo/track-pack wheels, what sidewall did you choose? And will it reduce/increase the gap?
Stock...
255-40-19
255-40-19
I am picturing...
255-35-19
275-30-19
I am on Coilovers so the car is lowered, but still have some gap.
Thanks in advance!
Stock...
255-40-19
255-40-19
I am picturing...
255-35-19
275-30-19
Thanks in advance!
if the goal is less gap, you need a taller tire. Your best bet is 275/40 in the 19' variety. stock 255/40 tires are 27.03". 275/40 are 27.7" All other sizes you mentioned are far shorter
![Headspin](https://themustangsource.com/forums/images/smilies/headspin.gif)
Having the Coilovers put on the car lowered with it, is making me confusing as far as filling the gap & clearing the bottom vs. good stance. When my Coilovers were installed at first, the car was too low that the bottom will scrap everywhere. So I raised up about 1/2 inch and now it's good. Gained a bit of gap it seems though.
Those adjustments were all done based on the Stock Brembo wheels & tires. Now that I'm replacing the tires, what size to go with and do I need to adjust the height or lol. Also, not sure where I got this 'Shorter tires = Cooler' impression.
Don't we have to go One size down in rear if want wider??
How about this then:
255/40/19 in front
275/35/19 in back
Thanks for kind advise. I was thinking backwards somehow shorter tires would fill the gap ![Headspin](https://themustangsource.com/forums/images/smilies/headspin.gif)
255/40/19 in front
275/35/19 in back
255/40/19 in front
275/35/19 in back
255/40/19 in front
275/35/19 in back
255/40/19 in front
275/35/19 in back
Your car looks awesome by the way! Love those wheels with Sterling Gray
And thanks, it only took 2 years to deside on wheels
firstang001
11/23/15 01:00 PM
