screaming mad hawk pads on tps rotors.
It hasn't worked thats why I'm on my third set of pads in a month in a half. I have had ceramic pads on my vehicles in the past and didn't have any issues and that's why I went with these pads.
I cant speak for the ceramic Hawk pads, however what I am talking about is the bedding procedure to ensure the brakes are the most effective. You said you have had issues with the noise but not the actual braking. What I disagree with Ponywars about is the procedure for bedding the pad, since the point of heating the pad is to transfer a film of pad material which helps in the pad gripping the rotor, and most likely promotes an even wear of the pad.
This morning I took the car back apart and change the pads over to the hps pads and painted the rotors and rear calipers gloss black. I now have around 50 miles on the new pads and no noise. Thank you guys for all your help with my brake issues now I can tackle my handheld tuner issues. John.
MRGTX
9/16/15 08:08 AM
