Popping noise coming from rear suspension.
Hi, I been having some bad luck with my '12 mustang gt. I have the oem 18x8 wheels and tires, everything else is stock. The dealer swapped out my front lower control arms 4 times, but it didn't fix the creak from the bushings. I kind of just learned to deal with it. So now there is a popping sound coming from the rear wheels. The noise in the rear is different from the front lower control arm creak, this is more of a popping noise. This squeak/popping noise occurs going over any speed bump and small/big pot holes in the pavement. Anyone have an idea what this could be? do you think a simple lube of the rear suspension components will take care of this pop noise?
Hi, I been having some bad luck with my '12 mustang gt. I have the oem 18x8 wheels and tires, everything else is stock. The dealer swapped out my front lower control arms 4 times, but it didn't fix the creak from the bushings. I kind of just learned to deal with it. So now there is a popping sound coming from the rear wheels. The noise in the rear is different from the front lower control arm creak, this is more of a popping noise. This popping noise does not occur going over speed bumps slowly, it only occurs when driving over small or big pot holes at about 15-20 mph. Anyone have an idea what this could be? do you think a simple lube of the rear suspension components will take care of this pop noise?
what was wrong with the rear sway bar end link? dried up bushing? I don't have any time to take my car to the dealer right now cause of my work schedule. If I can wait till the summer that'll be ideal, but I don't want to damage the car more by waiting.
I do know that none of the factory bushings are geaseable on the S197s, so there's not much you can do other then replace them.
Waiting wouldn't do damage (provided it's just bushings), as long as you can deal with the noise.
Please PM me with your dealer and best daytime number so I can escalate this for you again.
Deysha
interesting. i've had probably a similar issue on my '13 gt. in some places i'd expect to hear it, i don't like over a speed bump. seems to me it would happen over small but bumpy snow covered roads going as little as 5mph. dealer replaced left rear strut, then the endlink. i believe i still have it, but it's been a little warmer (30's d F) and not really any snow so no washboard. popping sound could definitely define the noise i hear (and the dealer tech). i have been thinking of it as more a "hollow clunk". i'm living with it for now, but will bring it back in in a week or so when i have them mount my new wheels/tires. dealer has been very good for me so i'm not worried.
that sucks - I want to change out the entire suspension package, however I had my suspension problems fixed by swapping out the LCA's (just once)...... i don't have that sound - sorry you do I'd so be pissed (good thing I have a great service dealer)...
