Popping noise coming from rear suspension.
Old Mar 11, 2013 | 12:16 AM
Will3212's Avatar
Hi, I been having some bad luck with my '12 mustang gt. I have the oem 18x8 wheels and tires, everything else is stock. The dealer swapped out my front lower control arms 4 times, but it didn't fix the creak from the bushings. I kind of just learned to deal with it. So now there is a popping sound coming from the rear wheels. The noise in the rear is different from the front lower control arm creak, this is more of a popping noise. This squeak/popping noise occurs going over any speed bump and small/big pot holes in the pavement. Anyone have an idea what this could be? do you think a simple lube of the rear suspension components will take care of this pop noise?
Old Mar 11, 2013 | 06:48 AM
kylerohde's Avatar
Originally Posted by Will3212
Hi, I been having some bad luck with my '12 mustang gt. I have the oem 18x8 wheels and tires, everything else is stock. The dealer swapped out my front lower control arms 4 times, but it didn't fix the creak from the bushings. I kind of just learned to deal with it. So now there is a popping sound coming from the rear wheels. The noise in the rear is different from the front lower control arm creak, this is more of a popping noise. This popping noise does not occur going over speed bumps slowly, it only occurs when driving over small or big pot holes at about 15-20 mph. Anyone have an idea what this could be? do you think a simple lube of the rear suspension components will take care of this pop noise?
Will, you have the worst **** luck with your car. Rear suspension noises seem to be commonly either A) the rear sway bar end links/bushings or B) the weatherseal around the trunk. I'd have your dealer check those out first.
Old Mar 11, 2013 | 07:32 AM
69Mach1-409's Avatar
Our 2012 6'er had the same issue. Took it to the dear and it ended up being one of the rear swaybar endlinks.
Old Mar 11, 2013 | 11:31 AM
Will3212's Avatar
what was wrong with the rear sway bar end link? dried up bushing? I don't have any time to take my car to the dealer right now cause of my work schedule. If I can wait till the summer that'll be ideal, but I don't want to damage the car more by waiting.
Old Mar 11, 2013 | 11:39 AM
I honestly don't know. I own the car, but the gf is the one who drives that car. It was under warranty, so I told her to take it in. They said they replaced the endlinks and that was the end of it.
I do know that none of the factory bushings are geaseable on the S197s, so there's not much you can do other then replace them.
Old Mar 11, 2013 | 11:54 AM
kylerohde's Avatar
Waiting wouldn't do damage (provided it's just bushings), as long as you can deal with the noise.
Old Mar 13, 2013 | 12:48 PM
FordService's Avatar
Hey Will3212,
Please PM me with your dealer and best daytime number so I can escalate this for you again.
Deysha
Old Mar 13, 2013 | 05:30 PM
5.0 power's Avatar
They need to replace the rear sway bar. I had the same problem also. Now no noise at all!
Old Mar 13, 2013 | 05:48 PM
2013kAB's Avatar
interesting. i've had probably a similar issue on my '13 gt. in some places i'd expect to hear it, i don't like over a speed bump. seems to me it would happen over small but bumpy snow covered roads going as little as 5mph. dealer replaced left rear strut, then the endlink. i believe i still have it, but it's been a little warmer (30's d F) and not really any snow so no washboard. popping sound could definitely define the noise i hear (and the dealer tech). i have been thinking of it as more a "hollow clunk". i'm living with it for now, but will bring it back in in a week or so when i have them mount my new wheels/tires. dealer has been very good for me so i'm not worried.
Old Mar 22, 2013 | 10:56 PM
Will3212's Avatar
i just recorded this video of the noise today,
Old Mar 22, 2013 | 11:01 PM
0tter12's Avatar
Same as mine. It's at the dealer now and I'll update early next week
Old Mar 22, 2013 | 11:59 PM
Xar's Avatar
Xar
that sucks - I want to change out the entire suspension package, however I had my suspension problems fixed by swapping out the LCA's (just once)...... i don't have that sound - sorry you do I'd so be pissed (good thing I have a great service dealer)...
Old Mar 23, 2013 | 12:04 AM
Will3212's Avatar
so is this noise the rear sway bar or something else?
Old Mar 23, 2013 | 07:12 AM
0tter12's Avatar
They are saying it's the bushing on one or both of the arms/brackets that are on the rear sway. I'll add pics and details when it's done
Old Mar 23, 2013 | 09:15 AM
Will3212's Avatar
the rear sway bar end links and end link bushings?
Old Mar 24, 2013 | 12:24 PM
0tter12's Avatar
On these. I'm not sure top or bottom.
Old Mar 25, 2013 | 07:42 AM
Exactly what they replaced on the 6'er. Not sure weather it was the top or bottom that went bad as they just replaced the whole piece.
Old Mar 25, 2013 | 07:56 AM
Brandon302's Avatar
If it was the bushings couldn't it be fixed by just re-greasing them?
Old Mar 25, 2013 | 08:10 AM
They're none geaseable
Old Mar 25, 2013 | 09:23 AM
Brandon302's Avatar
I know they have zerk to add grease but I bet you could pack them a little with new grease.
